First post, by Jackhead
- Oldbie
I try to get System Shock working on my DOS PC (5x86 64MB Ram), but get problems starting it.
Im using the cd version with SVGA and that stuff. As Sound card im using a CT-1600.
On install system freeze when i try to set the digital sound. I tryed all options for SB with auto and manual settings.
Than i set no digital sound and install the game (musik is set to midi and work fine).
After i installed the game when i try running sshock or cdshock the system freeze after i start the exe.
I tryed serval memory setups but not sure whats wrong.
Is there a patch or known problem ?
My config dont look right i think?:
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
