First post, by Vipersan
I was recently gifted an Imac G5 which for me was a bit a bit daunting on account of NEVER used one..
This one has the built in camera and I believe this makes swapping out the 3.5 inch sata hard drive a bit more difficult than normal
Not that there appears to be anything wrong with the 160gb drive in it...but I would like to eventually get at least 500gb in there...and have triple boot.
Mac OS ..a version of windows and a version of linux.
I believe this is possible with a program called Refit.
My first reaction with any system I obtain...particularly one I'm unfamiliar with is ..clone the hard drive/os.
I figured I could do this with a 500gb external drive in a usb caddy..
I have already blanked the drive and created 3 partitions on it using the IMACs disk tools.
The first one being 160gb for the MAC os clone.
I was pleased to find the cpu was an intel core2 duo ...which I believe is the better option.
4gb memory is definately a plus as well.
...and the side slot dvd r/w is in working order.
So to getting a clone image of Snow Leopard...(the entire OS HD)
I read that the process involved starting the G5 with the command and R keys pressed..
..which would start up in recovery mode...?
Sadly this doesn't work for me...no matter how long I press those keys it just re-starts in the main OS.
Can anyone advise on what I might be doing wrong ?
..is there another way to achieve my goal ?
I've also read a firewire hd caddy is the way to go...but I simply dont own one...
A very nice gift I guess ..but at the moment is nothing more to me than a very nice DVD player..
My only experiences of anything Apple end at the IIe
    512.15 KiB
    676.59 KiB
    629.4 KiB
    609.61 KiB
Reply 1 of 5, by paradigital
You won’t be able to triple boot Windows on a G5 (unless I’ve missed something fundamental in the last 5 or so years), BootCamp is only for Intel Macs, not PowerPC.
Reply 2 of 5, by Vipersan
paradigital wrote on 2023-05-28, 10:45:
You may well be right...but this youtube video is indicating a triple boot is possible...
https://www.youtube.com/watch?v=RbO44y4UpKY
Like I said..I simply dont understand MAC OS at all...so all new(bie) to me.
First job in this process for me..is to clone the existing OS to a larger HD before any experiments..
I wouldn't even consider this if my gifted computer wasn't intel based..
see first photo.
cheers
Reply 3 of 5, by paradigital
That video is an Intel IMac (says so in the title).
I’ve just realised that yours is Intel, not G5. You might want to change the thread title and not refer to it as a G5 😉
In which case you can easily run BootCamp to run Windows alongside Mac OS, and as you’ve seen, Linux also.
The simplest way for you to clone your existing HDD is just add it as a USB disk and clone it using Carbon Copy Cloner or another 3rd party utility.
Reply 4 of 5, by Vipersan
paradigital wrote on 2023-05-28, 11:56:
That video is an Intel IMac (says so in the title). […]
You'll have to forgive my incorrect identification...title edited.
Like I say...this is all new to me.
Reply 5 of 5, by Ryccardo
Vipersan wrote on 2023-05-28, 10:01:
That came with Lion (utility partition on disk), and/or the firmware update which launched shortly after and probably only for later models (utility partition in ramdisk downloaded on the spot), no big deal as it's for Lion only and it doesn't do more (okay, you get a web browser) than what you get by booting an OS X installer 😀
With an Intel Mac the utility is certainly reduced (you have good USB boot support, and even without a working Mac I had good success directly imaging a Mac OS DVD to a flash drive), but might be worth grabbing one the rare times you see one going for cheap!
You don't need it (though it's certainly a nice Mac-styled boot manager), but keep in mind the annoyances involved - you're pretty much required* to use BIOS emulation and a nonstandard hybrid MBR to run Windows, you can't boot in BIOS mode from USB, yours is probably old enough to have the "Select CD-ROM boot type" bug meaning you can't boot any dual-mode BIOS/EFI optical discs$ without a real PS/2 keyboard you can't connect, etc...
* on my early 2011 MBP it means giving up AHCI unless you use a custom MBR that reconfigures the chipset to enable it, or you can install it anyway in EFI mode which means giving up the integrated soundcard, the latter was fixed since some 2013 (!) Air model...
$ Ubuntu long had a "Mac" version which really means "BIOS only", only recently-ish a decent guide to make EFI-only images came out, speaking of which - if you do really have a 32-bit EFI you get all the compatibility fun people with mid-2010s Windows tablets got 😀 🙁
Might want to read Rod's site (by the inventor of gdisk and refit, even though the latter has been partially succeeded by "refind") - I found it the best practical reference to GPT and EFI, pure and applied to Macs 😀
https://www.rodsbooks.com/gdisk/
https://www.rodsbooks.com/efi-bootloaders/
https://www.rodsbooks.com/refind/
