First post, by Andriy
HI.
I have just repaired the damage from battery of 486 motherboard.
Model looks like: Chaintech_486SPM
Now the keyboard can not be detected. I found, there is no +5V on the AT plug.
I measured:
on Pin 5 - 0V
On Point 1 - +5V
Resistance of J1 - appr. 30 MOhm
Resistance of L5 - infinity.
Connection looks like: Point 1 - L5 - J1 - Pin 5 (in series)
What is L5??? Inductor? What is nominal value?
I think the resistance of J1 is too high. What can be nominal value?
Can I just apply +5 to Pin 5 directly?
Thanks!
    241.05 KiB
Reply 2 of 6, by Andriy
wiretap wrote on 2023-05-31, 16:24:
See if fuse F1 is blown.
I see only C1, JC1 (jumper) and then two "green" L5 and J1
I see marking F1, but no part.
Probably you mean with F1 - "my part" L5.
If it fuse, then infinity resistance makes sense! Blown.
For what current do I need a new fuse ?
And what can be J1 or part below fuse? They look very similar... Just distance between rings is little bit different.
It looks like someone replaced it with a resistor.
I would say no. The soldering looked as original. Also oxidated.
Reply 3 of 6, by bogdanpaulb
You need 2 of this: https://www.ebay.com/itm/175117812292?_trkpar … 7Cclp%3A2047675 , fixed the link with one that has the color coding so you will understand better. The actual value is in your case 10 uh with 10% tolerance, 1/2 w should be fine.
Reply 5 of 6, by wiretap
Looks like there are at least two hardware variants of this board. The earlier rev has the fuse and I was looking at the schematics for that. Yours has two ferrite cores. The poster above linked the correct parts.
My Github
Circuit Board Repair Manuals
