First post, by Trashbytes
G'day fellow collectors,
Looking for some ideas on how to safely store these older Lithium batteries, I have a few older laptops that still function just fine but after seeing a number of videos on spicy lithium hot pockets it got me thinking on just how many of these things I have stored around the place. Just thinking about it reveals I have a good number of lithium batteries around from Laptops to Tablets and old phones batteries, I wonder if they are dangerous if they are discharged and not being used.
Since these batteries are in storage still in the device and don't get checked very often, would it be best if I removed them and found a hot box to store them in ..just in case they decide to do the devils work and burn the home or shed down ?
How do you guys deal with this in a safe manner that protects both the home and device ?
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 1 of 7, by Pierre32
In the workplace they would be classified as hazardous items requiring correct storage procedures, technically.
https://worksafe.nt.gov.au/forms-and-resource … n-the-workplace
As much as I'd like to say I have them all stored in a dedicated steel cabinet in the shed, yeah nah. They're scattered through every drawer and cupboard. A whole bunch of the explosive devices live right under my bed.
Realistically the risks arise:
- When charging
- If damaged or swollen
- If stored in bad conditions (moisture, extreme heat)
I remove batteries from most things when storing, whether it's CMOS batteries in mobos or just AAs in remotes. Must confess I lazily leave the batteries in old laptops though. Under my bed.
Reply 2 of 7, by Trashbytes
Pierre32 wrote on 2023-06-05, 03:51:
In the workplace they would be classified as hazardous items requiring correct storage procedures, technically. […]
- When charging
The Swelling/Bloating while being stored is the bit that worries me, especially tablet/laptop batteries though 18650 type laptop batteries shouldn't bloat or go nuclear as they seem to have much better integrity than LiPo pouch types.
Reply 3 of 7, by wiretap
If I have questionable lithium batteries, I replace them. Questionable means I get less than 25% of the original charge / runtime, or it is beyond 6 years old, or it has any visible degradation, or it is below 3.2v per cell when I test it.
Replacing the batteries isn't that hard at all.. I picked up one of those pocket spot welders from Aliexpress for cheap, and I can usually find the correct cells for replacement (or ones that fit well enough), whether it be a pouch or cylindrical cell. The time consuming part is taking an existing device apart, or some of the laptop removable battery shells that don't like to open easily.
My Github
Circuit Board Repair Manuals
Reply 4 of 7, by Trashbytes
wiretap wrote on 2023-06-05, 11:18:
Whats the safest way of destructively opening these laptop batteries, the 18650 ones seem simple enough to refurbish since it usually one cell that has died, I'm guessing a Dremel type of tool with a emergency burn box near by ?
Ive been watching a few Big Clive videos on resurrecting dead 18650 cells by charging them low and slow to get them back above their "dead" voltage, not sure how viable this would be for 15 year old 18650 laptop cells but seems like it might be worth a shot.
Reply 6 of 7, by Thermalwrong
Sorry for the long post, there are a few things I'd like to add.
My preferred method is to twist the pack, it might break a weld-point or two but it's much safer for both me and the device, than trying to pry it open with tools or cut it with a knife. Twisting the pack will eventually break the plastic welds then you can start prying. Sometimes the pack has glue / tape holding it together and if prying into the cell, only ever use a plastic tool to do so. Cylindrical cells are a little bit more tolerant of poking but you'd damage the insulation on the cells or cause a short potentially.
I have used a dremel with a mini circular saw cutter which I find is good for cutting plastic in brief bursts until the wheel gets hot enough that it melts the plastic.
The real risk is opening up a lithium polymer pack, if a metal tool were to go into the pack, these only have a thin outer layer so puncturing the cell with say a screwdriver is far more hazardous and could cause a short between the cell's layers, which will cause a lithium fire. In which case a burn box could work but the energy output might be great enough that it wouldn't be possible to get it in there in time. If a lithium polymer pack is puffed up then it should really just be disposed of, especially if it was charged. I know of some instances where people dealing with lithium cells say in RC cars or a power wall, have had their houses burn down. Then there's phone shops where a tool slips and punctures a phone's lithium cell, there's lot of videos on Youtube of that happening.
Do not open up a battery pack to replace cells unless there's no other good option and you know what you're doing. A lithium battery pack is meant to be treated as a sealed unit and in my opinion there's a lot of specialist knowledge required to replace cells in a pack safely, which is why you don't really see cell-replacement services anymore.
Replacing cells is only necessary when the pack doesn't function and mix&matching cells in a pack is dangerous. Putting a fresh cell into a used pack could create an imbalance in voltages / capacities where cells could more easily be over-discharged or over-charged, damaging the cells or resulting in thermal runaway (fire). Loose metal swarf left in a pack from soldering or cutting while replacing cells could cause shorts too, it's very tough to replicate factory quality / conditions to achieve the same level of quality and safety that the pack was designed to originally.
Beyond that, lithium batteries have controller chips that perform charge balancing, prevent over charging & discharge and track the battery state. If tampered with, these controller chips can sometimes shut down rendering the pack inoperable and you may need specialist paid tools to fix that.
Mostly I only bother with NiMH packs for my old Toshibas since they're somewhat safer to work on and pre-date such chips.
Laptop battery packs can hold up very well over time if stored at between 20 to 70% charge at a stable temperature. The pack's circuitry will drop this charge over time along with the self-discharge of the cells so they'd need topping up maybe every couple of years. But I have packs that are 20 years old that still charge and can still run properly. Of course some packs have bad cells and that drops the capacity down significantly but unless you intend to use an old computer as a portable I do not recommend messing with the battery pack.
I find that very old lithium cells especially the 17670 type with low energy density (~1200mah per cell) from the 90s do often still hold charge. Unlike NiMH cells which just about always leak, these very old Lithium Ion cells can often still be charged in the laptop and run for a period of time. Out of maybe 10 PA2487u Toshiba Satellite 400-series batteries, only one would throw an error and that pack when dismantled did have something leaking from the cells and was disposed of.
I think that's because they have more parallel cells - laptop batteries that just have 3x batteries in series and none parallel (3s1p) like the Toshiba Libretto don't hold up so well. The PA2487u is I think 3x series and 3x parallel.
Old laptops from the era that I'm interested in (1990 to 2000) only used 17670 and 18650 cylindrical cells and some 103450 prismatic cells. These all seem to be not especially hazardous when stored, though I've seen prismatics damage themselves from over-discharge & poor storage. If they go 100% flat like to 0 volts and have done so over a long period of time, it's usually safe to recharge them. It's only un-safe to recharge them when they won't charge at all, which usually indicates a fault in the pack where one or more cells has an internal short and can't be charged back to its operating voltage safely. But it it can't be charged it's often safe to keep since battery packs are often structural elements 😀
I have Lithium polymer equipped tablets from 2014 that are still going strong and haven't puffed up from use, but I do charge them up / run them every few months.
Phone batteries get run a bit harder and I've had to replace a few of those now but none that have puffed up thankfully.
Modern laptop batteries are a different story, I've had good experiences with Lenovo, my T440's batteries are holding up after 9 years. But my Dell Latitude from 2016 & some at work which have lithium polymer cells did puff up, damaging the laptop casing. Those I'd just dispose of and try to get a replacement original manufacturer battery, cheap OEM battery packs are a lottery and I'm happy to just run that Dell laptop from mains power now.
Reply 7 of 7, by wiretap
Trashbytes wrote on 2023-06-07, 11:58:
They usually have internal press clips, but it takes a lot of force so you need thin bladed screw drivers. You kind of have to work your way around to find where they are first to avoid breaking them. It is an art.
Don't try to revive a dead 18650.. You might get good voltage, but you'll have severely deminished capacity and you risk burning things down.. Just buy new cells. They aren't terribly expensive.
My Github
