First post, by lordsmeef
Hello! This is my first post here.
So I have my parts for my first gaming pc. basically all original and the last time I used this system before it was taken apart. My x1900 XT booted up and worked perfectly fine with it. Now as I put it back together, it's like the board tries to detect and interface with it (you can definitely see the longer boot time before it turns over), but in the end is unable to interface with the card. I know that the CPU and board work because it kicks immediately to onboard graphics. I know the PCI-E Bus is good because I threw in a MSI HD 7770 GHZ into it and it booted up with that. and I know that the x1900 XT is 100% working because I threw it into a FM2+ system and it kicked on immediately with normal behavior. Any idea why this might be happening? Any answer would be appreciated, thanks!
