First post, by tomcattech
- Member
Trying to flash the Bios on an FIC KA-6100 Slot 1 for larger hard drive support (40 GB) as it currently will not recognize the drive in any form.
It is a PCB\Rev 1.2 Board
According to everything I have been able to dig up, the latest\greatest Bios update is:
BIOS ID: 11/09/1998-691-596-W877-2A6LFI2CC-00
OEM ID: Version 1.1eI patched for HDD to 128 Gb
File name: 610011EX.bin
Upon boot up, current bios shows as: Version 1.1 eI
On the Bios chip it shows: 1.1 els
Motherboard jumper set to:
Flash ROM size: 1 M
ROM Voltage: 5 V (Should I be changing this to 12 v?)
When using AWDFlash 8.99 I receive: "The Program File's Part Number Does Not Match With Your System"
There is no way to override as I have tried several command line switches.
When using AWDFlash 5.3 in an attempt to bypass the warning, the program freezes at any selection other than to quit the program.
I'm pretty much at my wit's end here.
Any ideas?
I either fix it or break it permanently... there is no try.
