First post, by oh2ftu
Hello there.
Due to happendance (it's a long story) I'm looking for a S7 motherboard that'll cache 256MB ram with a Pentium 233 MMX - and be ATX form factor.
That's why 430HX (practically) and 430TX are out of this race (very few 430HX ATX motherboards were made).
I did my diligence regarding both Ali aladdin V and Via MVP3 and the latter seems to be more readily available. At least if one wishes to find a Ali V rev G or later.
But about the MVP3 then. There are a host of boards that have veen available in multiple cache variations:
  • AOpen AX59 Pro -> 512K and 1M available
  • EPoX/ProNiX EP-51MVP3E-M // ENMIC/NMC NMC 5VMMX 512K/1M
  • EPoX/ProNiX EP-MVP3G-M (1MB cache) // ENMIC/NMC NMC-5VMX
  • EPoX/ProNiX EP-MVP3G5 (2MB cache)
  • EPoX/ProNiX EP-MVP3G2 (1MB cache)
  • ENMIC/NMC NMC-5VMX2
  • FIC PA-2013 512K and 1M available
  • Shuttle HOT-597 512K and 1M
  • Tyan S1598 1M / 2M
Looking at retroweb, the Tyan is listed as modification possible.
How about the others? many have an empty L2 cache footprint on the pcb.
The chips would have to match, naturally. And sometimes the TAG would need updating.
Has anyone done this?
Reply 1 of 12, by Skyscraper
You can add the PC Chips M577 to your MVP3 list. The M577 (as far as I know) always comes with 1MB of cache.
Reply 2 of 12, by The Serpent Rider
Actually 2M.
Reply 3 of 12, by majestyk
I did this with some DFI mainboards recently:
Re: DFI K6XV3+/66 L2 and K6BV3+/66 L2 cache upgrade
It easiest when the mainboards footprint for the TAG chip allows 32-pin chips.
The Serpent Rider wrote on 2023-06-22, 08:49:
Actually 2M.
I´m not so sure here, since the PA-2013 has a 28-pin TAG chip. All 4 chips populated on a PA-2013 probably means 4 x 256K chips.
Reply 5 of 12, by majestyk
The Serpent Rider wrote on 2023-06-22, 12:01:
I cannot find a picture with a 32-pin TAG. Of course it´s possible there was a (later) revision with full TAG support.
Edit / correction: I did find a picture of a full featured PA-2013
The attachment tag_32_1.PNG is no longer available
So Serpent Rider is right - there´s a 2MB version of the PA-2013 and the necessary TAG-chip is provided.
Reply 6 of 12, by oh2ftu
Actually, looking at a few (not so good) pictures of the Shuttle HOT-597, there seems to be a 28pin TAG-chip, but there are four pins unused on the board.
Officially, there was only a 512K and 1MB version of it. Also, there is one "affordable" on ebay (512K).
A picture on TRW shows T35L6464A-Q5 for cache but I can't make out the TAG ram: https://theretroweb.com/motherboard/image/hot … 84599209677.jpg
Reply 7 of 12, by majestyk
The TAG chip is a 256K one, for 2MB cache you could replace it by a 512K (32-pin) chip. There are also empty jumper / resistor positions nearby so I would _assume_ a 2MB upgrade can be done, but be prepared to do some research to find the jumper (zero ohm resistors) settings you need. And there´s a risk of failure if there´s a faulty layout or if you cannot find the correct settings.
Reply 8 of 12, by rasz_pl
majestyk wrote on 2023-06-22, 12:14:
https://akiba-pc.watch.impress.co.jp/hotline/ … 26/newitem.html https://akiba--pc-watch-impress-co-jp.transla … &_x_tr_pto=wapp
FIC PA2013
(MVP3,ATX,2MB,AGP1
 ,PCI3,PCI/ISA1,ISA1,DIMM3)
13,800 Tsukumo PC Main Store II
14,800 i2 DOS/V Senka Tokyo 3rd store
15,800 BLESS
 New version with secondary cache increased to 2MB. This is the first Socket 7 motherboard with 2MB secondary cache. The previous maximum was 1MB.
 The PMSRAM, which is used as the secondary cache, has a sticker with the letters "MT63V3212Q-5 9842A", which seems to be the model number, attached.
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
Reply 9 of 12, by dm-
did upgrade from 512k to 1m for my TEKRAM P5M3-A+
the board did not accept a new 512k tag ram so i just upgraded the cache chip. (a bios limitation?)
The attachment tekram.jpg is no longer available
The attachment tekram1.jpg is no longer available
The attachment tekram2.jpg is no longer available
board can run @133mhz with cache enabled.
all you have to do is just replace cache chip and switch 0-ohm resistor R118->>R117
Reply 10 of 12, by majestyk
A 512K TAG chip is needed for 2MB L2 cache ONLY.
When upgrading L2 from 512K to 1MB there´s no need to replace the TAG chip, 256K is sufficient.
Reply 11 of 12, by dm-
the idea was to get 2mb. unfortunately board detect only 1024 mb and it is not booting.
(no initialisation for tag in bios?)
there were no 2mb tekram boards in the wild.
Reply 12 of 12, by nickles rust
That is nice work soldering SMD chips so close to the plastic socket! Thanks for sharing your result. I don't think there are many 133MHz socket 7 boards working with cache. Do you have a good source for those cache chips? I recently picked up an epox board that I'd like to try upgrading.
