Dreamblaster not working
First post, by Kouwes
I‘d like to use a Formosa ES1688F MP-000023 with an X2GS or S2 in my pentium233MMX for DOS games.
The card is jumpered at 220, 5 and dma 1. IDE is disabled, Gameport is enabled.
Sound FX works in both Doom and Duke3D, but there‘s no music. Well there is, if I select Soundblaster (port 220) for music but that’s obviously not what I want.
The S2 and X2GS are ok, both work well on a CT2230.
I also tried Soft MPU but that didn’t help.
Any thoughts?
PS: I found a posting on amoretro.de from someone with the same card and issue.
Reply 1 of 4, by konc
My first thought was the wavetable header volume, maybe there is some mixer/configuration software where you can check it's not very low or zero?
Reply 2 of 4, by Pierre32
Try Aux B level or similar in the mixer.
Reply 3 of 4, by Kouwes
I‘ll check the mixer when I get back home in a week.
Reply 4 of 4, by Thermalwrong
Are you running the initialisation software for midi for that soundcard? I know that my ESS ES1868 (or maybe 1688, can't remember) won't give any MIDI output until it's run that in DOS. I remember having a similar issue to what you're seeing and having to spend a while figuring out how the card is supposed to be set up in DOS, I think it's ESSCFG.EXE.
You could try testing it out in Windows instead to see if that helps, since once drivers are installed in there, it should initialise MIDI in Windows just fine. You can select MPU401 output in the Multimedia settings and that will output to the Dreamblaster.
If you try that and it also fails with a known good MIDI / waveblaster header setup - which is probably not your problem because yours works with a CT2230, another issue I had with mine is that I somehow blew the component that handles the MIDI input serial data. I was able to work that out because it would work over USB but MIDI input on the waveblaster header did not work. That's less likely to be your issue but I do recommend testing out USB MIDI to see whether that works as a last resort.
