First post, by Brobearaz
Using DOSBox for the first time and can't find the answer to this one.
I have succesfully (as far as I can tell) gotten to the point where I launch the .bat file that starts the game (outside of DOSBox) and instead of the game starting I get this:
Path of AD&D game disk 2:
E:\AD3WIZ\GATEWAY\
I have both the DB folder and the game folder on drive E, anything I put there just gets added with another \ and it waits for another input.
Have I set it all up wrong or does this game just not work with DB?
Reply 1 of 7, by eL_PuSHeR
It seems you may have to check some configuration file for correct paths. You may need to try with and without backslashes (\).
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 7, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
The games should work. I guess did something wrong... How did you mount harddisc in dosbox?
Mirek
Reply 3 of 7, by Brobearaz
I tried it two ways:
mount e e:\ad3wiz and mount e e:\ad3wiz\gateway
both give me the exact same results when I get to the go.bat command.
Reply 4 of 7, by Brobearaz
What has me even more baffled is that I can get Pools of Darkness to run fine which is one of the sequels and came off the very same disk.
Reply 5 of 7, by HunterZ
Why aren't you mounting it as a virtual C drive? Some games expect to be run from the C drive instead of something else...
Reply 6 of 7, by mirekluza
DOSBox Moderator
What about mout e e:\ ? If you do what you did the path E:\AD3WIZ\GATEWAY\
of course does not exist in DOSBOX...
Mirek
Reply 7 of 7, by Brobearaz
Got it working! Thanks everyone.
