First post, by newtmonkey
Hello,
I'm not sure how best to describe it, so I went with "garbage" or "snow."
I've got a dedicated DOS machine (P133) that I've recently been using after not using it for a few months. I've noticed some "garbage pixels" on the screen when playing games, usually just 2-3 pixels that are totally white regardless of what the actual color should be. The locations of the pixels seem completely random, but tend to be toward the center of the screen. Once they show up, they stay there until the screen is updated (switching to another screen in a game, etc.), but eventually come back. It's not an issue with the monitor afaict, since they are not there all the time.
In such a case I'd suspect that the video card is dying, but are there any other parts that could be causing this? Faulty RAM?
I can take a picture if it helps, since it seems to occur pretty reliably.
Reply 1 of 3, by wbahnassi
My best is on faulty VRAM
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 2 of 3, by Putas
In case of snow underclocking the memory can help. Never have I seen the snow concentrated in some areas though.
Reply 3 of 3, by newtmonkey
Thanks for suggestions, both of you! I'll try swapping the video card first.
