First post, by koraxcz
I would like to extract midi-like music from an old DOS game "Star Trek: Judgment Rites". The music files are not directly accessible, but seem to be inside game archive files which are extracted or somehow opened while the game is running. The files are of these types: .Dir, .Run, .001, .002, .003. Does anybody experienced have a guess how I could extract the contents?
Reply 1 of 3, by Falcosoft
koraxcz wrote on 2023-06-25, 09:25:
Hi,
I do not know the game and I have just looked at it but I have noticed that in each level(?) related subdirectory (e.g. LIGHT, MADNESS, NOMAN etc.)
there are files with .AD, .GM, .MT, .OPL extensions. These most likely denotes Midis for different synths such as Adlib, General Midi, MT-32 and OPL3.
If you look inside these files the file header is very similar to .XMI (Extended Midi) file format, but not quite the same.
http://www.vgmpf.com/Wiki/index.php?title=XMI
XMI has the FORM section right at the beginning, but these files contain the FORM section some bytes later. Both contain the XDIRINFO section but the de facto XMI standard XMIDFORM section is missing from these files and you can find only XMIDz...
So I'm 99% sure that these files contain the Midi music data, but it seems that in a somewhat non-standard format.
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 2 of 3, by koraxcz
Thanks for looking into it. What you wrote certainly makes sense, but - and pardon the newb question - what did you use to browse the .DIR files?
