First post, by raist
Hi,
I have a BC3486UL MOBO, with 386 and 486 PGA sockets, 5xISA and 1x EISA slots. Board is in quite good shape, but doesn't boot.
i checked a BIOS chip and it's broken or erased - mostly 0x00, some bytes are 0x80.
If someone has working BC3486UL board, please share a BIOS dump, read with programmer or NSSI program.
I would be very grateful for your help 😀
Reply 1 of 7, by Disruptor
I am sorry, this is not an EISA board.
This slot looks like an EISA slot, but it seems to be a kind of local bus slot.
DO NOT TRY ANY EISA CARD IN THAT SLOT.
Funny fact: It has printed "EISA" near that slot, but it is not EISA at all!
It seems to be an incarnation of OPTi or Orchid local bus which used the same connector than EISA does.
An EISA board typically should have 4 or more slots looking like this.
Perhaps you can try a BIOS from this thread:
486DLC cache coherency blues and headaches
Reply 2 of 7, by raist
The description next to the connector says that it's EISA, but maybe it's a Opti Local Bus - it's not a problem for me.
Problem is, that the BIOS chip is empty and i need a valid BIOS dump to revive it 😀
Reply 3 of 7, by Horun
Agree do not try that EISA slot. I would try BIOS from this one: https://theretroweb.com/motherboards/s/cachin … 3486u#downloads
Same brand and same exact chipset including the ICS cmos/clock/timer chip, has MOST of the exact same jumpers.
Reply 4 of 7, by raist
Thanks for advice. I did it and mobo is working 😀
Reply 5 of 7, by Horun
raist wrote on 2023-06-25, 17:39:
That is great !
Reply 7 of 7, by Anonymous Coward
There are only a handful of EISA chipsets for 486 class systems. Unless your board has one, then that slot is guaranteed to not be EISA (despite what the silkscreen claims).
