First post, by envagyok
Hy everyone,
Please help identifying the Sound card above.
I think this is a Soundblaster Pro Clone dual OPL2 card.
Please share opinions, initialising (software/driver), jumper settings
Thank any help and infornations
Reply 1 of 4, by cyclone3d
I bet it works with the same set blaster settings as the CT1330A
Current settings per your picture are:
A220, I7, D1
Unsure of what the GS jumper is for.
The SET BLASTER line in autoexec.bat should be:
SET BLASTER=A220 I7 D1 T4
The T setting might need to be T5. I forget which one is correct.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 4, by Grzyb
Indeed, looks like 2 x OPL2, therefore T2
T4 is for SB Pro2 (OPL3), T5 for SB Pro MCV (Microchannel).
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 3 of 4, by cyclone3d
Grzyb wrote on 2023-06-28, 15:04:
T4 is for SB Pro2 (OPL3), T5 for Microchannel SB.
I really hate all the conflicting info about the T setting out there.
I had documented it at one point but don't have access to it right now.
YMF7x4 Guide
Reply 4 of 4, by Grzyb
This looks legit - https://nerdlypleasures.blogspot.com/2010/06/ … d-blasters.html
T1 - SB 1.x, SB MCV
T2 - SB Pro (2 x OPL2)
T3 - SB 2.0
T4 - SB Pro2 (OPL3)
T5 - SB Pro MCV
T6 - SB 16, SB 32, SB AWE32, SB AWE64
