First post, by RockstarRunner
Well, I've run out of ideas....
System:
I have a 486 pc, with a FIC 486-GAC-2 motherboard.
It is running bios version 3.276GN1
Board has a single IDE header
I am using a CF adapter board with a CF card as a hard drive. This is connected at the end of the IDE cable, and jumpered as Master.
I want to connect an optical drive on the same cable, using the middle connector, jumpered as Slave.
Using a 512MB CF card, the PC boots OK.
Using a 1GB card, the PC boots OK.
Using a 512MB card and an optical drive, the PC boots OK.
Using a 1GBB card and an optical drive, the PC gets stuck just after counting memory, right before you normally hear the floppy drive seek. NOK.
So the only thing I change, is the size of the card, and it refuses to boot.
If I am quick, I can still get in to the bios, but when doing the disk detect, it freezes trying to find C.
Notes: when switching cards, I am setting the geometry in bios, and testing, before adding the optical drive.
I only have a single ISA slot, which is populated with a sound card, so I can't add an xt-ide or anything.
So... I think I'm just screwed here, and the bios won't allow the optical if I go over 512mb.
Does anyone have any thoughts?
*EDIT* - Solved
rasz_pl was 100% correct
Reply 2 of 19, by rasz_pl
CF cards so probably same deal as sata-pata adapters Re: Motherboard refuses to see other IDE hard drive
tldr: CF card actually needs to explicitly support master/slave logic in IDE mode, not all did
Reply 5 of 19, by Horun
Another option is to use an IDE connector on a sound card (ie: SB16, etc) for the cdrom with the "quirky" 1Gb CF.
Reply 7 of 19, by RockstarRunner
1GB industrial card arrived, and unfortunately it behaves like the other >512MB cards I've tried. I.e. fine until I turn on the optical drive, then freezes after memory count.
I'm out of ideas, short of trying other CF IDE adapters, but at this point I don't want to throw any more money at this.
408.2 KiB
577.23 KiB
260.69 KiB
510.84 KiB
Reply 8 of 19, by RockstarRunner
I borrowed a couple of CF IDE adapters from a friend.
658.65 KiB
No luck with running an optical drive using these, either. Same issue.
I can even run that dual card adapter with a 512MB & a 1GB card, in master/slave without a problem.
This must be some weird issue with the Ide controller on the motherboard and optical drives.
Reply 9 of 19, by rasz_pl
IDE is just a name for few IO port addresses accessed over ISA bus. Actual IDE controllers are on the HDD/CD drives.
Your 1GB cards have insufficient compatibility. To be fair no CF card manufacturer probably ever cared about supporting CD drives on same IDE channel.
Reply 10 of 19, by RockstarRunner
Even that industrial one? Specs say it does true ide. I've tried 6 cards total, and only that one Cactus 512mb works with an optical drive. I'm not spending anymore money experimenting on CF cards, I've already dropped nearly $100 on the damn things.
Reply 13 of 19, by RockstarRunner
sangokushi wrote on 2023-07-13, 21:32:
Just curious, does it boot properly if you move the IDE cable + 1GB card + optical drive to another PC?
It's a good idea, and I had thought to try just that, I'll report back when I've done it.
rasz_pl wrote on 2023-07-13, 20:14:
should have started with SSD and SATA-pata converter
Perhaps, but the bios forces a max size of under 2GB, so I was looking for storage options that would be small enough. I've not seen any SSDs that small, though I suppose you could burn a bunch of the space by resizing the disk. Also, I wanted it to be easily removable for transferring files.
Reply 14 of 19, by squelch41
If you can, try using XTIDE - solves loads of these weird conflicts in my experience especially when they are around card identification/device conflicts
V4P895P3 VLB Motherboard AMD 486 133MHz
64mb RAM, CF 4Gb HDD,
Realtek 8019 ethernet + XT-IDE bios ROM, ES1869 soundcard, VLB Cirrus Logic GD5428 1mb VGA
440bx MSI 6119, modified slocket , Tualitin Celeron 1.2Ghz 256mb SD-RAM, CF 4GB HDD, FX5200 gfx
Reply 15 of 19, by Jo22
RockstarRunner wrote on 2023-07-13, 19:23:
"True IDE" is one of three modes that CF cards support.
The other two are "PC Card I/O Mode" and "Memory-Mapped I/O".
http://www.interfacebus.com/CompactFlash_Memo … ule_pinout.html
If you're using an USB card reader, some of those non-IDE modes might be used, perhaps.
Edit: If this was a gaming PC, I'd simply use the IDE/ATAPI port of a sound card.
They're being made for CD-ROM drives, after all.
Reply 16 of 19, by RockstarRunner
I only have one ISA slot, which I already mentioned, and it's got an Orpheus 2 in it, so no room for xt-ide, and no ide header on the card... Yes, I really wish these awesome modern sound cards had that feature too, but I totally get why it's not worth the effort.
Reply 17 of 19, by squelch41
RockstarRunner wrote on 2023-07-15, 06:48:
Crap -sorry, totally missed that sentence in your original post!
Think you *might* be able to add option roms direc tly to a system rom (eg https://www.plop.at/en/bootmanager/rom.html) but I have to say, I've never tried it.
Reply 19 of 19, by RockstarRunner
Just to conclude this issue I had, rasz_pl was exactly correct when he stated it was that the CF cards I had tested were not correctly supporting Matser/Slave functionality.
I was able to get a 2GB Cactus industrial CF card, and that , like the Cactus brand 512MB card worked perfectly when chaining a slave optical drive off of it.
During my testing I also tried a SATA/Pata adapter, but that turned out to be bad, something wring with the chip I guess, it got real hot, and the PC never recognized there was a drive attached.
I also tried a standard 3.5" HDD and that worked fine, but was never going to be an option for fitting in the case, mostly this indicated I should still see what CF cards I could get access to to test.
In summary, out of 7 CF cards I tried (including Transcend Industrial type), only the Cactus brand industrial cards worked. Now I won't take CF compatibility for granted in the future.
Thanks for all the advice given.
