First post, by amauget
- Newbie
Greetings to all,
I recently acquired an Asus P/I-P55T2P4 v3.10 motherboard equiped with a Cyrix 6x86L-P200+GP CPU but no RAM.
I bought 5 pairs of EDO stick (16 Mb and 32 Mb). I put a PCI VGA card (ATI Rage XL) and fired the mobo up.
Of course, the CMOS battery has dried up, as the posting screen mentions
The first thing I noticed was the BIOS setting weren't saved. Then I launched Memtest86 2.01+, it crashed immediatly :
After using the clear CMOS jumper, Memtest86 2.01+ launched but crashed with an Unexpected Interrupt error :
Then I switched to Memtest86 3.2. It launched flawlessly but report tons of errors :
I cannot boot MS-DOS : the boot starts but crashes at an early stage, without any message. So I can't flash the BIOS.
I have no way to test the CPU and RAM on another motherboard. I've tried all the the pairs of EDO sticks, same problem. I changed the PSU to no avail.
I change the jumpers :
- Voltage regulator from 2.9V to 2.8V
- Bus frequency from 75 Mhz to 66 Mhz
- Bus frequency from 2.0x to 2.5x
I inspected the motherboard, no signs of damage.
I'm almost stuck right now. Reading the manual carefully, the CPU doesn't appear to be supported. But the seller says everything was working before the mobo was put away years ago.
Did I miss something ? Does the motherboard requires a new CMOS battery to work correctly ?
Thanks a lot.
