First post, by 1strail
Hi,
Was wondering if anyone has either of these cards and what's been your experience. Found on Tindie here:
https://www.tindie.com/stores/kdehl/
Thanks!
Hi,
Thanks!
Not me yet, sadly. But I think the microphone input is cool.
I remember using Wave Recorder in Windows 3.1x back in the day (has SB 1.5 driver).
I bought Sweish David's Blaster 1.5 replica. I live in the United States. The build quality seems nice, but I am probably not the best judge. I jumpered mine to output line level and have tried a handful of games in my IBM MMX desktop.
It sounds fantastic. I have never had a real OPL2. Ive had countless OPL3s and a couple of Solo1s, even one of the good Crystal FM solutions. But this was a new thing for me. The Apogee opening jingle sounds better than I have ever heard it. Lemmings was nice. Even voice samples sounded great. I didn't know what to expect, but I played Star Trek 25th and also Duke Nukem 2 and 3D. Things not only sound great, but the different channels all seem to be mixed more appropriately than what I have heard rendered from other cards. Also I tried Jazz Jackrabbit and was a bit surprised by how nice and sharp the music was.
Also it needs no drivers! That made a difference to me in DOS7. It can be hard to have enough conventional memory to run Trek 25th.
The whole machine hard crashes when I try to play Fate of Atlantis. I do not know why
I uploaded some samples to the YouTubes.
TOMMY_THE_DOG wrote on 2023-07-18, 17:16:I uploaded some samples to the YouTubes.
Thanks for posting! Just a note but Jazz Jackrabbit doesn't use OPL2 (FM synth). It's tracker music that uses digital samples.
I just recently order the SB 1.5 clone. While I have a real SB 1.5 with CMS, I find it noisy as hell.
I'm curious to see how the clone compares and if it provides cleaner output.
Shponglefan wrote on 2023-07-18, 17:36:TOMMY_THE_DOG wrote on 2023-07-18, 17:16:I uploaded some samples to the YouTubes.
I had no idea about Jazz. It sure sounds good. I uploaded a few other samples as well. They all feature this card.
https://www.youtube.com/watch?v=FanPB7_Z6iQ
https://www.youtube.com/watch?v=nSmjljQQg8Q
https://www.youtube.com/watch?v=LbcxprRm_P0
Great feedback! The only complaint I have, and I haven’t yet determined if it’s even the sound cards fault, is when I turn everything off, there is a faint buzzing sound and that’s with the speakers at 75%. If I unplug the audio cable from the sound card, it goes away same if I pull the plug from the IBM 350 I have it installed in. Trying a different non PnP tonight to see if it’s the card or something in the PC.
Other than that, it sounds fantastic and the perfect compliment to my Roland midi’s. I did remove those from the equation to make sure it wasn’t that since both the midi and the sound card plugs into by Bose computer speakers, different jacks.
I also got David’s Gravis board, but haven’t set it up yet. It’s a bit more complicated.
1strail wrote on 2023-07-20, 20:59:Great feedback! The only complaint I have, and I haven’t yet determined if it’s even the sound cards fault, is when I turn everything off, there is a faint buzzing sound and that’s with the speakers at 75%. If I unplug the audio cable from the sound card, it goes away same if I pull the plug from the IBM 350 I have it installed in. Trying a different non PnP tonight to see if it’s the card or something in the PC.
Hi, maybe that's a ground loop or related issue?
If so, one workaround would be to use galvanic insulation.
Two capacitors in-between the L/R wires should do (one per channel in series, roughly 1uF).
Cleaner approach would be to use two 1:1 AF transformers (AF=audio frequency) in-between. Or an opto-coupler.
The parts can be found in any Radio Shack type of store, but maybe there are also ready-made devices for sale.
I wondered about the stereo. I thought the older SB 1.5’s were mono, but they clearly have 2 jumpers for amplified vs. line out. I’ll look around for the ready made devices you mentioned.
I was also thinking of getting a hardware mixer like a mackie 5 channel which might at least mask the buzzing when every thing is off. It’s very slight.
1strail wrote on 2023-07-21, 15:57:I was also thinking of getting a hardware mixer like a mackie 5 channel which might at least mask the buzzing when every thing is off. It’s very slight.
Maybe that's caused by a tiny bit of DC on the audio cable?
If so, galvanic insulation would block that DC, too.
1strail wrote on 2023-07-21, 15:54:I wondered about the stereo. I thought the older SB 1.5’s were mono, but they clearly have 2 jumpers for amplified vs. line out. I’ll look around for the ready made devices you mentioned.
The SAA1099s for C/MS compatibility are stereo.
