Intel 440FX
First post, by doublebuffer
Can you tell me anything about this chipset, wikipedia knows barely anything. I am planning to build Pentium Pro system around it, is it a good choice or better suited for P2? Late pro or early P2, well that is the question... 😀
Reply 1 of 8, by Gmlb256
The chipset is adequate for Pentium Pro and early Pentium II CPUs. It only officially supports up to 66 MHz FSB and doesn't support SDRAM, UDMA nor AGP.
Reply 2 of 8, by maxtherabbit
Frankly it ain't all that great. The pentium pro was a bit held back by it. Put a PPro on a BX board and you really see it sing
Reply 3 of 8, by Disruptor
maxtherabbit wrote on 2023-07-13, 02:09:
At 66 MHz, is the LX so bad against the BX?
Reply 4 of 8, by Warlord
Disruptor wrote on 2023-07-13, 02:46:
If apples to apples, meaning BX running at 66mhz too with a comparible CPU. Probably not. Otherwise its enough to make a impact.
Reply 5 of 8, by maxtherabbit
No the LX was a significant improvement over the FX
Reply 6 of 8, by Gmlb256
No, the 440LX has nearly all the features that the 440BX has except support for 100 MHz FSB.
Reply 7 of 8, by OSkar000
For a Pentium Pro there isnt much to choose from. Intel 440FX would be the most common one if you dont go into server hardware.
The limitations is something you have to live with and try to overcome. SCSI is a pretty nice upgrade from IDE in these systems 😀
Reply 8 of 8, by dionb
Consider the age of the stuff...
No, i440FX doesn't have AGP, UDMA or SDRAM because it's a 1995 chipset and none of those things existed in 1995. It's contemporary with the i430FX and basically shares the same feature set, just with a GTL FSB and a northbridge that can address more RAM.
Want 1997 features? Get an i440LX. With a P2.
