First post, by mkarcher
Continuing the effort started in these threads
I now added BIOS patches for the Adaptec 1520B / 1522B to add BIOS support for disk drives above 8GB to the newer "scsi_edd" repository. The enables LBA-capable versions of Windows 9x to access big drives on these controllers.
In this case, I wrote the source code in a kind of literate programming approach: You can read the assembler source code file for the BIOS patch as a complete explanation, how that patch works and why it is written that way. A deep link directly into that file: https://github.com/karcherm/scsi_edd/blob/v1.3/152xB115.asm
The BIOS for the 1522B will most likely not work on the 1520 or 1520A, as those chips use older Adaptec interface chips.
Reply 1 of 5, by Horun
Nice work ! yeah the AIC 6260 is not same as newer 6360
Reply 2 of 5, by Disruptor
We have tested it on an Adaptec 1520B with AIC-6370Q.
Please note that the corresponding ASPI2DOS.SYS may not need to be patched.
Reply 4 of 5, by mkarcher
Horun wrote on 2023-07-16, 20:14:
It seems like
  • AHA-1510/1520/1522 uses the AIC-6260, the most recent BIOS image I have is 1.4, copyright 1990
  • AHA-1510A/1520A/1522A uses the AIC-6360, the most recent BIOS image I have is 1.20L, copyright 1993
  • AHA-1510S100/1520S100/1522S100 (also S105) seem to be very similar to the A series
  • AHA-1510B/1520B/1522B uses the AIC-6370, the most recent BIOS image I have is 1.15, copyright 1996
The AHA-1510 controllers do not have a BIOS and do not have the support logic for the BIOS, like the ISA address decoder. So there won't be any BIOS patches for the 1510 series.
Reply 5 of 5, by mkarcher
weedeewee wrote on 2023-07-16, 21:02:
Can this work with a AHA-1535A ?
No. The 1535A seems to be a cost-reduced version of the 1540CF or 1540CP. Their architecutre is completely different from the 1520 architecture. The latest 154xCF BIOS already includes large disk support, so possibly the AHA-1535A does so, too.
