Optimizing K6-2 Build
First post, by LiquifiedBeef
Hello,
I have a Compaq Presario 5441 that I have been trying to optimize for Windows gaming, and need help with either optimizing it further or setting realistic expectations.
So far, I’ve seen considerable gains from your commonly seen BIOS tweaks and disabling the PCI sound card I had installed.
I have tried multiple Nvidia drivers ranging from 52.X to 81.X (latest). Performance remains the same.
That said, I feel as though something (Mobo?) at a lower layer that is capping performance. What leads me to believe this is I can only get 8-27 FPS when playing Half-Life regardless of resolution. Also, in Quake, I get smooth frame rate at the lowest resolution (300x200?). Quake is playable at higher resolutions, but a significant drop in performance comes as soon as I start increasing the resolution.
My current retro system’s hardware specs are as follows:
  • K6-2 475
  • GA-5SMM F5
  • GeForce4 MX 4000 64MB PCI
  • 384 MB RAM (PC100)
Any suggests are appreciated!
Thanks!
AMD K6-2 500Mhz
Nvidia GeForce4 MX 4000
64 MB RAM
Reply 1 of 21, by Warlord
LiquifiedBeef wrote on 2023-07-17, 03:17:
I have tried multiple Nvidia drivers ranging from 52.X to 81.X (latest). Performance remains the same. […]
I would use 45.23 drivers with that card. It would help.
Reply 2 of 21, by badmojo
It could perhaps help to reduce the amount of RAM? I don't think your motherboard can cache that much. If you had a K6-2+ then that's not an issue from what I understand - more details here: Cacheable ram?
And it might be worth trying some of the K6-2 optimisation tools here: https://www.philscomputerlab.com/k6-2-2-3-resources.html.
I use CTU in Win98 and get a boost out of it.
Reply 3 of 21, by dionb
Second the dropping RAM to 64MB. It's not going to make a massive difference but definitely will help.
Another thing you could do is downgrade to a GeForce2MX GPU. That would let you use older, less bloated Detonator drivers. Again, won't make a massive difference but can help.
Finally, a K6-2 475 runs at 5x 95MHz. You can almost certainly overclock that to 500MHz, which increases not just CPU clock but also memory and PCI. It's only 5% but on So7 platforms, anything that improves FSB will generally give 1:1 improvement in application speed.
You're correct in saying that your motherboard is limiting you - this is a low-end integrated VGA chipset. With Gf2MX/4MX cards, PCI will be bottlenecking performance. This was a bottom-scraping low-end machine back in the day and was never inteded to give best performance to the components on it. You could of course (if it's standard ATX, whcih Compaqs weren't always around that time) look into replacing the motherboard, but then it's hardly the same machine anymore.
Reply 4 of 21, by Disruptor
dionb wrote on 2023-07-17, 06:20:
That amount of cacheable RAM depends on the amount of cache on the motherboard.
You can try to detect the amount of L2 cache with the tool SpeedSys 4.78 from dosbench suite.
You can try to detect the cacheable area with the tool ctcm from heise/c't magazine.
dionb, your calculation may be wrong. With 512 kB of cache, a cacheable area of 128 MB should be achieved.
Reply 5 of 21, by Warlord
Top google result tho.
Somone reccomended leaving the 1st memory slot empty to get rid of shared memory.
http://www.k6plus.com/phpBB3/viewtopic.php?t=1725
What I'm reading is max cache is 64mb, if you want to cache more you need a K62+. Then you can cache 128.
    46.67 KiB
Reply 7 of 21, by Warlord
normal K6 doesn't have L2 cache so it relies on external L2 cache to cache ram. Plus version have L2 cache and can cache ram without the exernal L2 cache that becomes L3 cache. That site says nothing about a normal K6, everything Phil is saying is about Plus versions so its irrelevant to the discussion.
if you disable the extenal L2 cache on non plus version, perfomance plumets, if you disable the L2 cache on plus version not much happens, except a drop in maybe 1-2 FPS likely contributed to just having less cache.
Reply 8 of 21, by marxveix
K6-2/3 best graphics card for me would be Geforce2 MX400 64MB AGP, then Geforce2MX 32MB AGP, if you can get PCI version of them, use older drivers (version 7.76 is good).Rage128 Pro is also nice with right drivers and OpenGL version if you do not use newer Directx7 games and stay more up to Directx 6.1 ones with that rage build. Still Nvidia OpenGL support is better and has directx7. If you have chance do get Voodoo2 12MB, add that for your setup.
https://www.techpowerup.com/gpu-specs/nvidia- … pci-64-mb.b1569
My best results are with one stick of memory and the size of the ram is important, for my Aopen AX59Pro (1MB) 1x256MB RAM is the best, get ram that has slower CL time at 100 or 133MHZ. If your motherboard has chaceable memory max @ 64MB then use that size,i tought that with 512KB it would be 128MB, still 64MB is good for Dos and Win9x, you can use lite version of Win9x os also.
https://www.litepc.com/98lite.html
Sometimes older chipset drivers are better than newer ones. Right chipset drivers are important, at least for my VIA MVP3 + other tweaks that this chipset needs to unleash the power. Use more games that has 3DNow support in it, if you miss more speed, use older games. Use higher resolution for you games (better picture, same speed) limiting factor is probably cpu not gpu. Use FSP speed 100MHz for your Motherboard/CPU.
https://web.archive.org/web/20001109071400/ht … dnow/optimized/
31 different MiniGL/OpenGL Win9x files for all Rage 3 cards: Re: ATi RagePro OpenGL files
Reply 9 of 21, by LiquifiedBeef
Warlord wrote on 2023-07-17, 04:41:
I have seen that 45.23 drivers are widely considered the best, but when I go to install the driver it does not detect a Nvidia graphics chip.
AMD K6-2 500Mhz
64 MB RAM
Reply 10 of 21, by LiquifiedBeef
badmojo wrote on 2023-07-17, 05:17:
Quick update: I pulled out two sticks of RAM leaving one 128 MB stick. This actually got my FPS up by like 5-10 frames in areas where I was getting decent framerate, which is pretty significant when you're talking sub 30 frames! However, the stuttering is still there. For instance, when playing Half-Life, frames drop to 0-8 and I get several stutters that are maybe .5-1 second long whenever enemies load into the game. This looks like a CPU bottleneck, but I believe it is this infamous motherboard.
When I am walking around and there is not much going on, Half-Life runs at a "smooth" 35+ frames. Performance tanks when enemies are loading in or the environment gets complex. I will keep tinkering with the BIOS to see how far I can push it, and will keep you updated.
AMD K6-2 500Mhz
64 MB RAM
Reply 11 of 21, by LiquifiedBeef
Warlord wrote on 2023-07-17, 08:41:
I played around with external cache, and I have found this to be the biggest difference in performance. When enabled, my highest framerate is 38 fps. When disabled, highest is about 26 FPS with stuttering in places I was not seeing it before.
I think at this point, I am going to nuke and repave the entire system to have a clean foundation to build on.
AMD K6-2 500Mhz
64 MB RAM
Reply 12 of 21, by H3nrik V!
That stuttering makes me think of issues I've had with 2 IDE devices sharing same cable, so take when one is being accesses, it clearly affects the other, IIRC I've experienced some stutter from that ...
Reply 13 of 21, by BitWrangler
Are you running the SiS chipset drivers? https://www.gigabyte.com/Motherboard/GA-5SMM/ … pport-dl-driver the UDMA modes will speed up HDD access and stop the drives from robbing CPU cycles, which may speed things up a lot.
Reply 14 of 21, by LiquifiedBeef
BitWrangler wrote on 2023-07-17, 17:55:
This actually helped with the stuttering a little but. Frames will still drop to 8 FPS, but the stuttering is basically gone. Thanks!
AMD K6-2 500Mhz
64 MB RAM
Reply 15 of 21, by LiquifiedBeef
H3nrik V! wrote on 2023-07-17, 15:21:
I checked, and my SD-Card adapter is the only device on the two connector IDE cable. It is using the first of the two connector on the cable.
Edit: I tried disconnecting the IDE cable from the CD-ROM drive, and I think it might have made a small difference? Stuttering was virtually gone after I installed the UDMA via the SiS Chipset driver BitWrangler suggested. This leads me to wonder if and how 80 wire IDE cables would work?
AMD K6-2 500Mhz
64 MB RAM
Reply 16 of 21, by marxveix
LiquifiedBeef wrote on 2023-07-17, 11:49:
45.23 driver was released before the GeForce 4 MX4000 was released, so this version will most likely not supported with you card. Maybe it works if card information added to this 45.23 driver inf, like in 7.76 driver you can add Geforce3 Ti200 support, but i doubt it, that it works for MX4000. Geforce3 is also one of the best cards to the K6-2/3+, but voodoo3 2000/3000 PCI would also be nice card to have and i still think that you get much more out of the K6-2 with Geforce2/3 and older 7.76 drivers.
Reply 17 of 21, by dionb
Disruptor wrote on 2023-07-17, 06:26:
That amount of cacheable RAM depends on the amount of cache on the motherboard. You can try to detect the amount of L2 cache wit […]
Incorrect in the case of the SiS 530:
https://softpixel.com/~cwright/papers/tech/0530DS10.PDF
Table 5.2-1 Supported Size of L2 Cache CACHE SIZE TAG RAM CACHEABLE SIZE 256K 8Kx8 32M 512K 16Kx8 64M 1M 32Kx8 128M 2M 64Kx8 256 […]
CACHE
256K 8Kx8 32M
512K 16Kx8 64M
1M 32Kx8 128M
2M 64Kx8 256M
512kB L2 gives 64MB cacheable, to do 128MB requires 1MB.
So if reducing RAM to 128MB already showed a clear improvement, dropping to 64MB will improves things further.
Reply 18 of 21, by LiquifiedBeef
dionb wrote on 2023-07-17, 19:55:
Incorrect in the case of the SiS 530: https://softpixel.com/~cwright/papers/tech/0530DS10.PDF […]
CACHE
256K 8Kx8 32M
512K 16Kx8 64M
1M 32Kx8 128M
2M 64Kx8 256M
I will try a stick of 64MB and let you know how it goes.
AMD K6-2 500Mhz
64 MB RAM
Reply 19 of 21, by Disruptor
LiquifiedBeef wrote on 2023-07-17, 21:12:
Fine. But please try the utility ctcm from heise/c't too (with the 128 MB module installed).
https://www.heise.de/download/product/ctcm-1825
