Action Replay
First post, by jibanes
Is it possible to simulate the behavior of the Action Replay on Dosbox/dosbox-x. I'm not certain how the action replay works, but essentially it breaks into the action replay rom and allows introspection of memory AND modify things.
I'm attaching a few screenshots of the Action Replay/PC. How can I have something like this with dosbox/dosbox-x?
    32.24 KiB
    86.99 KiB
    58.23 KiB
    89.42 KiB
Reply 1 of 13, by cyclone3d
Look up Game Wizard 32.
Not linking it here since the ling would be removed because "Abandonware".
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 13, by cyclone3d
keenerb wrote on 2023-08-01, 22:45:
gamewizard 32 doesn't work under dosbox.
I haven't tried it with DOSBox. What happens?
YMF7x4 Guide
Reply 6 of 13, by jibanes
The bottomline is that IDK why it doesn't work on dosbox-x but I took the latest dosbox-x and ran gwtutor.exe (using a google search for archive and Game Wizard 32 Pro 3.0) and it crashed dosbox-x with the following msg:
LOG: Flush STDIN
LOG: Flush STDIN
LOG: Flush STDIN
LOG: DOSBox-X has switched to max cycles, because of the setting: cycles=auto.
If the game runs too fast, try a fixed cycles amount in DOSBox-X's options.
LOG: Restart by keyboard controller requested
LOG: CMOS Shutdown byte 0x0a says to jump to reset vector 0b9f:05d6
LOG: E_Exit: Sorry, CMOS shutdown CPU reset method is not compatible with dynamic core
Maybe that's why, let me know what I can try, IDK what is a dynamic core TBH.
Reply 7 of 13, by cyclone3d
What about using simple core instead of dynamic?
YMF7x4 Guide
