First post, by bifflog
Heya,
Curious if anyone has any thoughts on what might be going sideways here, I walked through the following video...
https://www.youtube.com/watch?v=ZiSM5pUGab4
...in order to set up my Sound Blaster 16 VIBRA PnP card, and all seemed to go very well. When running Diagnose.exe all of the autodetect channels seem to work fine as well as the test 8bit, 16bit, and midi samples, running set shows the properly configured variables for SOUND, CTCM, BLASTER, etc. Unfortunately when running DOOM after restarting to MS-DOS mode, after running Setup and indicating correct values in that util, the game outputs no sound whatsoever. Wondering if anyone has run across this or any advice!
EDIT:
As it turns out, the config file that DOOM setup.exe is supposed to update with the sound card selections was set to read only (doh!). Got sound now!
Reply 1 of 2, by kixs
Have you tried running UNISOUND to configure the card and DOS? Then use correct settings to setup the sound in games.
Unisound:
UNISOUND - Universal ISA PnP Sound Card Driver for DOS v0.82a
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 2 of 2, by bifflog
kixs wrote on 2023-07-22, 06:16:
Unisound:
This could come in very handy, thanks for pointing me toward it,
