First post, by K-rnivoro
I'm building my own MT32-Pi but I cannot find the letter font so I can design the front plate in 2D and printing in 3D? Anyone?
Reply 1 of 4, by wierd_w
I'd be more apt to just trace it with CAD software if you have a good scan of the bezel.
I can make a quick and dirty .STEP and .STL combo for you, if you can find me a good scan (as in, put inside a scanner)
Reply 2 of 4, by K-rnivoro
Thanks wierd!! I have more than a scan: I'm sending you some illustrator files, jpg and also a pic with the measures. I've also included a pic with the best I could do using the litophane feature of Cura. If you could make it from a CAD, including the four holes that would be perfect! Oh, if you want to build your own Mt-32 Pi using my design, just let me know!!!
https://drive.google.com/file/d/13u-Otbte26vF … ?usp=drive_link
Reply 3 of 4, by wierd_w
the .AI files might be convinced to go through ps2edit and get spat out as an .IGS file for my CAD software.
Please hold...
OK. Here is a 3D object created from the illustrator files. Included inside is the 2D DXF I generated with PSTOEDIT.
https://drive.google.com/file/d/1C5g5xODYy0eq … iew?usp=sharing
It is 1mm thick, with 1mm tall lettering. It is available in .STP and .STL formats.
Reply 4 of 4, by K-rnivoro
wierd_w wrote on 2023-07-22, 16:42:
the .AI files might be convinced to go through ps2edit and get spat out as an .IGS file for my CAD software. […]
Please hold...
Beatiful made!!! Thank you very much!!!
I'll print it and let you know!!!
