dgVoodoo2 Vulkan output?
First post, by Zilch
Hi,
Would it be possible to have dgVoodoo2 pass its output API calls through DXVK for Vulkan compatibility?
If there were a checkbox under the API selection drop down menu, you could have dgVoodoo2 navigate to (for example if DX11 was set) "./dxvk/dxgi.dll" and "./dxvk/d3d11.dll".
Any thoughts? Perhaps the API overhead from doing DX9 > DX11 > VK is not worth it over DX12?
I reckon why not add it? Could be fun to experiment with, even if there are no performance gains over DX12.
Reply 1 of 3, by Krolin
You can already use DXVK on top of dgVoodoo if you wish: just copy dgVoodoo D3D9.dll (D3D8.dll or D3DImm.dll + DDraw.dll for older games) and DXVK d3d11.dll + dxgi.dll to the game directory. DXVK supports D3D9, so it's pointless to use dgVoodoo + DXVK in this case. You may also try D8VK for D3D8 games.
Reply 2 of 3, by Zilch
Seriously thanks for pointing this out. One of those stupid A2Q posts.
Just tested it, and it works well! Probably the only real way to play DX8/9 games in Linux.
Titles such as Pac Man World 2 need dgVoodoo2 otherwise there are all kinds of issues. Using the dxvk DX9 dll simply doesn't work as well as using both.
I don't really use Linux, but I am a Vulkan freak!
Reply 3 of 3, by Krolin
Zilch wrote on 2023-07-23, 15:51:
Yeah, early D3D9 games could be an issue. I recently had to use dgVoodoo for Colin McRae Rally 3 because SilentPatch crashes with DXVK :)
Edit: SilentPatchCMR3 Build 2.1 fixed DXVK incompatibility.
https://github.com/CookiePLMonster/SilentPatc … releases/latest
