First post, by naz
Bioforge is extremely laggy. I'm using DOSBOX on XP. any ideas?
Reply 1 of 5, by eL_PuSHeR
After searching the forums, it seems some people were able to run it using DOSBox. How did you try to run it?.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 5, by naz
Hi,
I finally got bioforge to work but (and i knew it was too good to be true):
it's EXTREMELY laggy. how do i get it faster?
Reply 3 of 5, by eL_PuSHeR
*** ONE THREAD per TOPIC, please ***
*** Merging Topics ***
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 5, by rgriff
From another forum, I found another user had his speed factor in 'install.opt' set to 3. Mine was at 20 ... I changed it to 3 and the speed is fine now using DosBox.
Reply 5 of 5, by HunterZ
Thanks for the follow-up post.
(Moving to DOSBox Games/Apps section)
