First post, by Warlord
98se is in a way a cumulation of work done to windows 95 to 98 Second Edition. Think of 98se as 95 Service pack 5.
The core OS didn't change it was improved on and bugs were fixed. By the time 98se released, all of the bugs from 95 and 981st had been worked out. 9x became basically as stable as it was ever going to be.
There a lot of 98se updates, however almost none of them have anything to do with gaming or system stability. Almost all of them are security fixes, and most of those are related to Internet explorer in some way.
They are actually not security fixes in reality, becasue there is no way to secure 98se outside of disconnecting it from the internet. They end up making the OS slower and in some cases more unstable and introduce bugs and regressions.
Some of the updates actually hurt the OS, like the WDM update, as it has shown to effect drivers and games.
So please, unless your system has a specific problem like its not shutting down properly, as there is around 5 different fixes that try to adress this problem. Just leave it alone.
That being said there are some updates I recommend installing.
MSI installer 2.0
NOVOLTRK registry patch to keep 9X from corrupting floppy disks
Direct X 7 and only higher version if the video card needs it. Otherwise newer version than 7a will break some sound cards, video cards and games.
TweakUI
VBrun 1,2,3,4,5
VC++6
nusb2.2e If you use USB
TCP 1.4 if you use tcp
Q240896 Open GL update
Doshere from 95 powertoys
WinG
Ie 5.5sp2 only if you have a program that needs otherwise dont update IE. Avoid IE 6.
Edit.
Rloew patches. I have nothing aginst them, and I recommend them if your system needs them especially large hard drive support, its better than official ones.
That just about covers it unless you have a specific problem in which case a specific update would solve, but not adding 30 updates to fix a problem that one update would fix and then intruduce 7 other problems.
MSI Installer2.0
https://archive.org/details/instmsi
Directx 7a
https://web.archive.org/web/20011005075954/ht … -US/dx7aeng.exe
Dun TCP 1.4
https://web.archive.org/web/20011128162030/ht … US/dun14-SE.exe
NUSB 2.2e
download/file.php?id=169568
NUSB 2.2.1e update
download/file.php?id=168398
VBRUN 1,2,3
download/file.php?id=168737
VBRUN 4
download/file.php?id=169320
VBrun 5
download/file.php?id=169321
VBrun 6 Sp4
http://web.archive.org/web/20230713024044/htt … /VBRun60sp4.exe
VC6 C++ run
https://web.archive.org/web/20230713023103/ht … stSetup_enu.exe
Rloew Patches
https://archive.org/details/rloewelectronics.com
Directx 7 CPL
download/file.php?id=169414
3D Controls
download/file.php?id=169416
Directx 7a Dsound Patch
download/file.php?id=169417
    Wing10.7z
    832.95 KiB
    42 downloads
    Q240896.7z
    323.18 KiB
    49 downloads
    DOSHERE.7z
    718 Bytes
    44 downloads
    TWEAKUI.7z
    71.75 KiB
    44 downloads
    NOVOLTRK.7z
    15.73 KiB
    48 downloads
    GPL-2.0-or-later
Reply 1 of 12, by Joseph_Joestar
I agree with this. For gaming purposes, all you need are the Windows Installer Update and DirectX. Both of these are required in order for certain drivers and utilities to install correctly.
Which version of DirectX to use depends on the hardware that you're running. Generally, you want at least DirectX 7.0a, since even the latest official Voodoo 3 drivers need that version. Going further is recommended if you're using a high-end Win9x GPU, like something from the GeForce FX lineup or the Radeon 9000 series. However, Aureal Vortex 2 cards don't like anything above DirectX 7.0a, so be mindful of that if you're using one of those.
Reply 3 of 12, by pentiumspeed
"NOVOLTRK registry patch to keep 9X from corrupting floppy disks" !! Should had known that back then! I create special disks for configuring computers by booting with these and absolutely must be careful not to accidentally get 98SE "mark" them hence ruining them.
Oh, hey, I vote to make this thread pinned to the top permanently as go to references.
Cheers,
Great Northern aka Canada.
Reply 5 of 12, by LSS10999
leileilol wrote on 2023-07-25, 23:10:
Why bother with patchwork ME transplant "service packs" when you could just install Windows ME? 😀
If considering using DOS then WinME is generally not a good idea. Despite there are some good efforts in properly restoring DOS functionality to WinME, the DOS 8.0 that came with WinME has some serious limitations.
Reply 6 of 12, by Warlord
Updated post with links to recomended updates.
If your system has some sort of specifc problem check this webpage and use archive .org to download the links.
https://msfn.org/board/topic/84886-the-comple … r-windows-98se/
Reply 7 of 12, by Warlord
I've discovered a hotfix to Directx 7a, a gaming related patch.
269604usa8
Another library update 3dcontrols that some games use. Includes all of the 3d control files.
3DCTRLS My fresh 98se contained 3 out of the 4 files. I was missing 1 file.
The dirextx7 CPL from the directx 7 sdk place file in system directory.
directx7 CPL
Added WinG library to the 1st post, some older games like win Doom need it.
download/file.php?id=169406
    269604usa8.7z
    228.99 KiB
    60 downloads
    3DCTRLS.7z
    54.06 KiB
    44 downloads
    directx7 CPL.7z
    36.58 KiB
    47 downloads
Reply 8 of 12, by smtkr
🤣. I actually can't fix my shutdown issue no matter what I try. It runs scandisk every single time no matter what. That's literally the only thing I wish I could fix. I think it just really hates a SSD on a startech adapter.
Reply 9 of 12, by Warlord
smtkr wrote on 2023-07-27, 23:35:
These updates are only for specific shutdown problems. don't install if you don't have this problem.
IDE Cache Shutdown FIX
You should try 273017USA8 and 290831usa8, Only intended to fix that problem.
273017USA8.7z
https://web.archive.org/web/20041210133528/ht … .com/?id=273017
SCSI miniport Shutdown Fix
The article above mentions you should install this hotfix also with the IDE cache fix. It's for scsi but many ATAPI devices use a SCSI miniport driver because the command set is the same for both ATAPI and SCSI.
290831usa8.7z
https://web.archive.org/web/20041210160543/ht … .com/?id=290831
The Common 98se Shutdown Supplement
This one is the common shutdown supplement that doesn't sound like it has anything to do with your problem. Don't install if you don't have that problem.
4756US8.7z
https://web.archive.org/web/20041204171536/ht … .com/?id=239887
USB Shutdown Fix
This Shutdown fix is caused by USB devices when used on specific hardware. Dont install if you dont have that problem.
https://web.archive.org/web/20041204172642/ht … .com/?id=240075
https://web.archive.org/web/20041204172642/ht … us/240075up.exe
ACPI Shutdown Fix
https://web.archive.org/web/20041210135605/ht … .com/?id=253711
https://web.archive.org/web/20040616174422/ht … /253711usa8.exe
Nvidia 6xxx 7xxx on 8x.xx Shutdown Fix
The final shutdown patch is an unofficial patch only for systems running geforce gt6xxx and 7xxxcards on 8x.xx drivers.
Don't use this patch if your using Rloews nvidia driver. Dont install this if you dont have that problem
ShutdownPatcher1522.7z
    423.44 KiB
    36 downloads
    4756US8.7z
    453.61 KiB
    39 downloads
    290831usa8.7z
    101.29 KiB
    40 downloads
    273017USA8.7z
    173.92 KiB
    37 downloads
Reply 10 of 12, by smtkr
@Warlord,
First of all, thank you for posting the list of patches and prooviding links to all of them.
Now, I have already tried all of those, but you might find this hilarious. I just tested something that I hadn't tried before. As part of the IDE Hard Drive Cache package (which you linked above), a registry key is created that adds a 2-second delay to the shutdown process to provide the hard drive cache time to flush to disk. Out of curiosity, I increased that to 4 seconds. I just had a clean cold boot (no scan disk), so... maybe it was a fluke, or maybe I just needed to increase the delay. Time will tell.
Reply 11 of 12, by Warlord
Happy to help. Sounds like that fixed it. Yea the KB Article alludes that the value can be changed to increase duration until it works. Hopefully this helps others facing the same situaltion.
The last option I guess is just to disable scandisk on reboot in msconfig, which would get rid of scan disk but not fix the problem.
Reply 12 of 12, by pentiumspeed
I need this thread stickied so I can have reference in future as you know I can't remember the name of this topic and I'm poor with searching to find this thread again.
This is GOOD reference than anywhere else.
Cheers,
