First post, by Mandrew
- Member
I have an old JBL 500bt headphone with a dead battery, it's charging for long hours and only lasts for 2 hours max.
I have a bunch of old smartphone batteries lying around, some of them are from broken phones that were barely used, like a Samsung 2000 mAh battery.
They are both 3.7V and li-ion type. Of course there is a size difference but I don't care, I'll just duct tape it to the side of the headphone, I only use it at home or during long, boring yard work. It's a workhorse.
The question is: is there some capacity limiter in these devices that prevent me from charging and using a 2000 mAh battery instead of the factory 600 mAh one?
It feeds from an external charger that is a standard 5V 3A USB phone charger.
