First post, by nizce
nizce
Offline
Hi!
I just bought a voodoo 3 1000(the 16MB 125Mhz one).
Since this version has no heatsink, I guess one is not really needed. But I’d thought it might not hurt to have it run a little bit cooler.
Anyone know what size of heatsink I should use?
I’ve googled and seems to be 40x40mm(guess the avenger chip is the same as the rest of the 3-series), if so does it hurt to go bigger than that?
