First post, by gryffinwings
Hi guys, I have an old Sony Viao PCG-FX190, it has a Pentium III 850MHz, 128 MB RAM, 30 GB Hard drive. I've got a brand new CMOS battery installed and I've got good universal AC power adapter.
Symptoms I am getting:
1. No video out on the screen or external monitor during power up, but the power LED is illuminated.
2. Hard drive makes sounds but the hard drive LED does not blink.
3. Cap lock does not work.
4. No audible beeps.
My thoughts are that the CPU isn't functioning properly, I have been able to remove it, and the thermal compound is hard as a rock, I am going to apply fresh and see if reinstalling it has any affect.
Feedback and advice is much appreciated.
    755.79 KiB
    802.29 KiB
    692.96 KiB
    543.51 KiB
Main Computer: Custom - Intel 12900K, Asus Nvidia 3080 Ti, 64 GB DDR5.
Retro Computer: Packard Bell Legend I - AMD 286, 640KB RAM
Retro Computer: Dell Dimension 4400 - Pentium 4 2.8 GHz FSB 400 MHz, ATi Radeon 9600XT, Sound Blaster Live!, 768 MB RAM.
Reply 1 of 4, by nfraser01
Thoughts:
  • Is the power supply providing enough amps?
    Does the coolign fan spin up - if jammed may prevent a boot
    Possibly a DC to DC circuitry fault?
    Have you toggled the external display on using keyboard shortcut?
Start by removing components to troubleshoot...
Once down to the bare motherboard check for "hot" chips
HTH
Reply 2 of 4, by gryffinwings
nfraser01 wrote on 2023-08-02, 16:18:
Thoughts: […]
Thoughts:
HTH
Power supply provides 4.5-4.9 amps.
Cooling fans spings up then stops.
Not sure how to test DC to DC circuitry
I have toggled the external display on the keyboard, but it doesn't do anything, likely because the laptop isn't posting, as I'm not getting any response from the lock keys either.
Checking for hot chips would be down to touch, as I don't have an infrared camera, although I do wish I had one, they are expensive though.
Reply 3 of 4, by nfraser01
gryffinwings wrote on 2023-08-02, 22:26:
You'd need the schematics/hardware maintenance docs if they exist... Beyond my skills anyway, but someone here may know.
Good, just wanted to check you had done this...
I meant definately using your hands - thermal cameras are too expensive, even second-hand 🙁
Hope you get a break with this.
