Kyro II and Abit BH6
First post, by dweeman
Hi everyone, have you experienced problems with these two pieces of hardware ?
I bought this video card recently on ebay, seller tested it working and i kinda trust him, but here at home it won't boot (motherboard is beeping and screen stays black), the system is ok and tested with an ATI rage pro and a GeForce 2 GTS (both AGP).
I tried a few things :
to boot with a PCI 2D card + kyro II and flash the bios with a gui utility i found, the tool gives me some checksum error and cannot erase the bios.
then i tried installing the driver anyway and windows became somewhat unstable, the video card shows in device manager but flags as a non working.
tried 2/3 and 1/1 settings for AGP in the bios.
I found this post regarding compatibility issues with AGP 4x but correct me if i'm wrong BH6 motherboard is 2x only.
Kyro II compatibility/stability issue? (Intel 845GE / ICH4 chipset?)
System is P3 600E, 256Ram, Abit BH6 (440Bx), win98.
Thanks.
Reply 1 of 5, by paradigital
Have you tried what I did regarding hot-plugging the card? If that works then it’s likely you’ll need the mods I did.
If hot-plugging gets you nowhere then you either have a much bigger compatibility issue between card and motherboard, or a dead card.
Reply 2 of 5, by dweeman
well i tried hot plugging the card when the PC starts and it stays the same (motherboard beeps and black screen), i guess this card will be staying in a box until i decide on a new project...
Reply 3 of 5, by stef80
From my experience, I could not run Kyro II on all boards.
For example, it worked great on Asus P4P800, but black screen on Asrock 775i65G (same chipset as P4P800).
Reply 4 of 5, by havli
Kyro II should run on i440BX just fine. If it doesn't, then it is probably damaged somehow.
AGP 4x/8x boards (chipsets) are completely different story as the Kyro II is known to have issues there. But on any AGP 2x capable board it should run.
Reply 5 of 5, by rasz_pl
hot plugging AGP card?!?!?!!!!!!!!!?!?! this is a recipe for fried everything
