First post, by william9
So I have two identical Riva TNT2 M64 16MB AGP cards and both of them have the same issues.
With Asus A7V133-C the 3D functionality is very bad, nothing I tested works properly, Quake 2 & 3, Unreal Tournament (using D3D) and 3D Mark 2001. Graphics glitches everywhere, this what Quake 3 looked: https://youtu.be/b4xKZQIDtzE
Switching to Abit AB-BH6 and now Quake 2 & 3 work fine, Unreal Tournament works if I switch it to use OpenGL but D3D is still a mess, 3D Mark 2001 is total garbage with this setup, even worse than with A7V133-C.
I tried two drivers so far, latest from Nvidia's site and one from previous generation of Forceware.
Since two similar cards have same issues I think it's about compatibility? I have never used these Riva cards when they were relevant, only GeForce cards.
Reply 1 of 3, by auron
william9 wrote on 2023-08-05, 09:09:
i'm assuming this is under 9x, the driver is most likely the issue - the last 9x nvidia drivers are really bad for TNT cards. don't have an exact version at hand to recommend but for starters, try something from around 2001. the differences between the boards may be down to the via chipset board requiring a certain 4in1 driver or such, which isn't an issue on 440BX that will work right out of the box.
Reply 2 of 3, by william9
Yes, I forgot to mention but Windows 98 is the OS. I downloaded older drivers from Phils Computer Lab site and indeed the D3D version of UT worked normally, interestingly OpenGL mode was now extremely slow slideshow, unplayable.
Reply 3 of 3, by bloodem
No, these cards are very compatible. What you are seeing is simply a driver issue (or a combination of driver/platform/other variables).
Try Detonator 7.76, a period correct driver from 2001, and everything should work just fine. Also, stick to DirectX 7.0.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
