First post, by JRRTolkien
Hi I'm having problems with some versions of dgVoodoo for Fable The Lost Capters, the first problem occurs with versions 2.6 up to 2.62.1 where changing the game resolution from the one forced by the dgvoodoo application causes a bug with lines in water , later versions fix this first bug but it generates a different one, essentially this second bug occurs with all subsequent versions up to the most recent 2.81.1, it happens that the aura of the characters is off-center. Both bugs are visible in the attached images. Anyone know how to fix?
