First post, by oldcomplover
I could not find similar post here.
This is what I have: I got 5.25 drive that is in a quite good shape and when I first turned it on it did work , it did read but after few disks scratched badly and I cleaned it, it stopped working altogether. Namely, it will react to commands but it will report fail,abort. I found that the controller wont step the head and head selection flips 0,1,0,1,......... index sensor works, track0 works, all motors do work properly, when commanded appropriate signals are sent but no head movement. I can see read signal is present and I can see pulses.
Is there anyone here with expertise in fixing and diagnosing this device?
Reply 1 of 3, by rasz_pl
>I cleaned it
you either forgot to plug something back (unlikely) or ripped some cable/cracked some connection in the process
Reply 2 of 3, by Deunan
oldcomplover wrote on 2023-08-09, 15:51:
no head movement
Can you move the sled by hand with the drive unpowered? It should move easily when pushed with one finger.
Reply 3 of 3, by dominusprog
Post a photo of the motor and the main board.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
