First post, by egbertjan
I have an ASUS p5a-b rev 1.04 motherboard with an AMD k6 550MHZ processor and it gives a -12v error in the bios see the picture.
The attachment BIOS1.jpg is no longer available
is actually 0,0V
I tried 3 different power supplies, 1 ATX and 2 AT power supplies, they all gave the same error on the -12V. See the pictures below for the specifications of the power supplies
1 The enermax e201p-v at power supply 200 Watt
The attachment enermax.jpg is no longer available
2 The Seasonic SSG-150g at power suppluy 150watt
The attachment seasonic.jpg is no longer available
3 The Startech ATXPOWER300 ATX power suppluy 300watt. Is a new power supply not used before
The attachment startech.jpg is no longer available
Does that mean a problem with the PSU or with the motherboard and can this cause problems for the operation of the PC? I haven't encountered any strange problems with the PC so far.
Who can tell me what the problem is here
Reply 1 of 2, by rasz_pl
There has been a lot of Asus boards experiencing monitoring chip failures (bad voltage reading). You can always measure on the ISA slot (be VERY careful, one probe slip and you can fry chipset), not that you will need -12V anyway.
Reply 2 of 2, by Horun
Agree with rasz_pl ! If the -12v measures OK then change the "halt on" in bios Standard Cmos page to "none".
added: and write it down on one of them yellow stickies and keep in the case or mobo box/bag for future reference if battery dies. Have been saved many time by my own notes IF I made them 😀
