First post, by nizce
Hi!
Is it possible to use SB live in DOS and get audio from the line-in jack while not using up to much resources?
The default mixer included with the dos drivers don’t list line-in.
I’ve tried the DOSMIXER (ek1m.exe) that I found here on vogons. And while it works, it eats up 30MB or so of expanded memory when launched so can’t run doom for example.
Any other solution?
Reply 1 of 5, by dominusprog
Well, you can solder a female jack to the CD-ROM audio cable and use it as line-in.
Something like this
https://www.amazon.com/V-MOTA-Headphone-Exten … 2126998&sr=8-72
Creative AWE64 Value ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 5, by Namrok
Oh! I think I know exactly what you are talking about!
So, if you were at all like me, you wanted to use the SB Live's line-in in DOS because you have another soundcard you want to use for DOS, as opposed to the SB Live's substandard emulation. I'm not sure why, and I believe the source code for the mixer is no longer available, but EK1M only wrecked my memory when I ran it after running SBEINIT. And I actually found that for my use case, where I was only using the SB Live as a mixer in dos, I didn't even need to run SBEINIT. Only EK1M to set the mixer settings. It didn't solve the problem, but it avoided it entirely.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 3 of 5, by zyga64
nizce wrote on 2023-08-15, 15:22:
Impossible ! I will check tomorrow. (I have such configuration: SB Vibra16s connected to line-in of SB Live!).
Edit.
Ah, OK. Looks like I didn't even tried to use SBEINIT before...
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 5 of 5, by nizce
Namrok wrote on 2023-08-15, 19:33:
Seems to be the exact same issue!
The reason for me is to route my output from my mt-32 connected to picogus to my SB live. And also get SFX from the emulated SB16 from the live. So need to use sbeinit I’m afraid 🙁
Only have one ISA port on my MB(P3B-f)where the picogus sits. So not optimal.
I’ll probably have to change motherboard to one with 2xISA slots so I can use the line in on my SB32 instead of the Live. Or use a external mixer, but like to keep the clutter to a minimum on my desk 😀
