First post, by vanfanel
- Member
Hi there
As soon as I select JOYSTICK as the control method in Disney's Aladdin, the character automatically walks to the left of the screen and doesn't obey to any input.
Is there a known solution, please?
Hi there
If you currently have timed=true in the [joystick] section of the dosbox-0.74-3.conf file, try timed=false.
Stick wrote on 2023-08-18, 17:38:If you currently have timed=true in the [joystick] section of the dosbox-0.74-3.conf file, try timed=false.
Thanks for your suggestion. I tried both timed=false and timed=true, but it makes no difference.
Is the game working with joystick for someone?
I only played a few minutes, but it seems to work fine, as long as I have timed=false. With timed=true, he constantly runs to the right. Sorry, I don't know what else you could try.
Stick wrote on 2023-08-19, 03:17:I only played a few minutes, but it seems to work fine, as long as I have timed=false. With timed=true, he constantly runs to the right. Sorry, I don't know what else you could try.
It is more convenient to use a keyboard to joystick mapper like Xpadder. This way you can add far more keys and functions
