MS-DOS 5.0 and DEFRAG
First post, by appiah4
I installed MS-DOS 5.0 on my 286 yesterday and was quite surprised to find out and be reminded that DEFRAG did not exist in that version of the OS.
I vaguely remember using some other software to defrag the hard drive at the time, and if my memory serves, it was Norton Utilities. Am I correct? What is the simplest way to add defrag to an MS-DOS 5.0 installation? My OCD brain wants to be able to sort the filesystem alphabetically 🤣
Reply 2 of 9, by Jo22
There also was COMPRESS utility (PC-Tools, Central Point Software).
v7 (modern)
https://www.youtube.com/watch?v=FIwrCLJSbRg
v6 (classic)
https://www.youtube.com/watch?v=cDDh7l3uXXM
v4 (ancient)
https://www.youtube.com/watch?v=BrKDi0xWlz4
Reply 3 of 9, by Yoghoo
I use Norton Utilities version 4.5.1 for this. Even works on a XT with MS DOS 5.0.
Reply 4 of 9, by appiah4
Thanks for all the advice, I'll just go with Norton Utilities v6.0 I think, as that seems to be contemporary with MS-DOS 5.0 and also happens to be what I remember using with my 486 at the time.. And it also seems to support 8086/88 as well 😀
Reply 5 of 9, by Jo22
"And it also seems to support 8086/88 as well 😀"
Ah, I see where you got this information from.. 😉
Later versions seems to have been compiled to take advantage of the 286 processor.
XT users could get them running, too, if they had a NEC V20/30. Which they hopefully had, anyway.
If they didn't, they were a bit silly, anyway. Still using an 808x in the 90s.. Pfft. 🙄😂
The arch rival product, PC-Tools, was being optimized from early on, without requiring the help of 286 op codes.
A few of its utilities were being licensed/used by both IBM and Microsoft (MS AV).
Though Microsoft did prefer Symantec utilities more, which finally found their way into MS-DOS 6.2x.
In simple words, the relationship was like this :
IBM PC DOS / CP's PC-Tools / White Wine
MS-DOS / Symantec's Norton Utilities / Sparkling Water
Anyway each to this/her/they own. 😁
Reply 6 of 9, by Yoghoo
appiah4 wrote on 2023-08-18, 10:19:
Great choice. I use an older version as it's a lot smaller and the XT I own only has a 20Mb HDD. 😜
Reply 7 of 9, by Jo22
^Double Space is an option. Did that with my 4, 77 MHz XT, performance was okay.
https://www.youtube.com/watch?v=5XxOtHodSBU
That XT also had an MFM/RLL drive with a lousy 20 MB drive, which was too little for that contemporary software, even.
A bit Quick Basic here, a bit Turbo Pascal here, some comprehensive semiconductor database there ..and the HDD, -err-, fixed-disk drive was basically full. *sigh*
Edit: Or alternatively, if you're running DOS 3.x on that relic and have a period. correct setup: You may want to have a look at Double Disk (Vertisoft).
It's a history drive compression software from the late 80s.
Later versions were being advertised as MS-DOS 5 compatible.
Reply 8 of 9, by Yoghoo
Jo22 wrote on 2023-08-19, 03:49:
^Double Space is an option. Did that with my 4, 77 MHz XT, performance was okay. […]
Sorry for derailing a bit.
Thanks for the suggestion. But had too much troubles with Double Space/Disk back in the day. So don't like to run it even nowadays. 😀 I run DOS 5.0 on it (it came with DOS 3.2) mainly because it's needed for the 250MB ZIP drive I use with it if I need something bigger or want to make a backup. Guest.exe doesn't run on older versions of DOS (there is a paid alternative btw which suppose to run on older versions but haven't tried it). Nice thing is that it runs almost at the same speed (= as slow) as the 20MB MFM drive.
But indeed got only Turbo Pascal, Lotus 1-2-3, 3 small CGA games and some utils and it's full. 😜
Reply 9 of 9, by weedeewee
Another option is to copy all the files off of the hard drive, onto another storage medium, then format /s the harddrive or delete the files, and then copy them back onto the hard drive.
et voila, defragmented drive.
Do not ask Why !
