First post, by copper
I have a Leading Edge Model D 8088/XT clone, which includes a built-in real time clock chip (a MM58167) on IO 300h. The Leading Edge system disks come with a CLKDVR.SYS file you can add to CONFIG.SYS that will keep DOS time up to date for you, assuming you have a battery for the RTC: https://jeffpar.github.io/kbarchive/kb/076/Q76454/
This works, at least in Dos 6.22, except that the year always reverts to 1980 on reboot. The rest of the time and date is correct.
Does anyone know why this might be happening? Is there a way to just set the year to 2023 in AUTOEXEC.BAT every boot?
Reply 1 of 11, by dominusprog
Is there any documentation on CLKDVR.SYS? According to Wikipedia, for a real-time clock to work the jumper J13 must be closed.
https://en.wikipedia.org/wiki/Leading_Edge_Mo … Modern_Upgrades
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 11, by copper
I set my XT-IDE to 340h, and my Intel 8/16 NIC to 260h, so they don't conflict with the clock on IO 300h. The Leading Edge diagnostic utility shows the clock as enabled. The clock seems to work fine (keeps the time, day, and month when the PC is shut off), it just always thinks it's 1980.
Reply 3 of 11, by dominusprog
Perhaps CLKDVR.SYS have some parameters that must be set. Also found this
https://stason.org/TULARC/pc/motherboards/L/L … REVISION-1.html
Reply 4 of 11, by copper
Maybe, but I haven't seen any reference to any options for it.
Reply 5 of 11, by dominusprog
Leading Edge Model D Operator's Guide 😀
https://archive.org/details/leadingedge_model … e4thed_d3187910
Reply 6 of 11, by copper
The Leading Edge diagnostic and master disk (DOS 3.1 and DOS 2.1) see the year correctly, so this seems to be a DOS problem. 1980 is the DOS default year. I guess CLKDVR.SYS doesn't set the year correctly on DOS 6.22.
Why, I don't know. The KnowledgeBase article says it's supposed to work.
Reply 7 of 11, by Jo22
Checkit! v3 has a clock test functionality. It'll test both DOS clock and hardware clock.
Not sure how many different RTCs it does support, though. 🤷‍♂️
Edit: The problem might be related to how DOS handles the RTC or how it updates things (all digits or just two for the year).
If I remember correctly, DOS didn't support RTCs before PC DOS 3.0 or similar.
The IBM AT RTC and compatible RTCs are supported, not sure about XT era RTCs.
Edit: IBM "supported" non-IBM PCs with DOS 3.30 first time.
Edit: The RTC could be an MM58167 (also used by AST SixPackPlus?)
Some drivers are available here: https://www.minuszerodegrees.net/rtc/rtc.htm
Reply 8 of 11, by copper
Oh, maybe the TSR hands DOS 6.22 a two-digit year, but DOS now wants a four-digit year. The TSR is only 735 bytes. It would probably be trivial to decompile and change for someone other than me.
Checkit 3.0 doesn't see it (maybe because of the non-standard IO port). DIAGNOSE.EXE from Leading Edge sees it.
I'll look for other drivers on that page. I see that CLKDVR.SYS is not listed. The 6PakPlus driver may work if I can change the base port.
Reply 9 of 11, by awgamer
Obviously leading edge has decided that the 80s are the best.
Reply 10 of 11, by weedeewee
looking at the datasheet for the mm58167B... How/where does that chip stores the information for which year it is ? 🤨
Do not ask Why !
