First post, by peter_shaw
Hello,
I am new to vintage computing and recently got my hands on an old pentium machine with an AT power supply.
I measured the voltages. Sadly, they were a little bit out of spec:
5 V rail: 6,5 V
15 V rail: 16,5 V
I tried to remove the AT power connector, but it would not budge.
Any pointers? Just blunt force?
I started the PC anyway and it runs fine and stable. Even installed Win 95 on it.
Would you advice to replace the power supply, or is it fine?
My humble vintage PC collection: https://www.peter-shaw.de/2023/10/vintage-pcs/
Reply 1 of 9, by zyga64
Standard AT PSU doesn't have 15V rail. 12V is max. https://en.wikipedia.org/wiki/Power_sup ... g_diagrams
Is this some special/ custom computer ? Or maybe you multimeter has bad battery 😀
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 2 of 9, by ciornyi
It's very high values and definitely have to be replaced.
DOS/95: PII266/128mb/AWE64/TNT
Win98: P3 900/256mb/SB live/3dfx V3
Win Me: Athlon 1333/256mb/Audigy2/Geforce 2 GTS
Win XP: E8500/2GB/SB X-fi/HD6850
Reply 3 of 9, by peter_shaw
I measured on an IDE connector. You are right, it should be 12 V, not 15 V. Maybe my multimeter is also bad? The PC runs fine..
Reply 5 of 9, by oh2ftu
Did you have any load on it?
Reply 6 of 9, by PC Hoarder Patrol
peter_shaw wrote on 2023-08-24, 09:34:
Any hints on how to remove the AT power connector from the socket?
Try gently rocking each connector front to back whilst pulling up on them - they can be quite stiff, especially if they've never been removed since installation (may also be some mild oxidation in play)
The attachment P8 P9 Removal.jpg is no longer available
then just tilt to clear any locking lugs
Any pics you have may make things clearer
Reply 7 of 9, by zyga64
Measure 12V line in another good known PC PSU. You will know for sure !
Reply 8 of 9, by peter_shaw
any pointers on atx to at adaptors? I just read there might be Problems with some soundcards because they need -5 V, which ATX doesn't provide?
Reply 9 of 9, by DerBaum
You can check if your cards need -5v if you look at the card and determinate if B5 of the ISA connector is connected on the card.
https://upload.wikimedia.org/wikipedia/common … SA_Bus_pins.png
Most of them dont use it...
The attachment Screenshot 2023-08-27 233700.png is no longer available
FCKGW-RHQQ2
