First post, by cambalinho
how read big disks drive?
i tried, without sucess, installing the 'ESDI_506.PDR' file.. but i get an access error\denie.
how can i fix these?
my objective is read a 500Gb's external hard drive NTFS.... using a NTFS pen with 16GB's is readed normaly. but not the 500GB's external disk
Reply 1 of 7, by jakethompson1
If you say it's external, it's presumably not IDE and ESDI_506.PDR wouldn't be involved anyway. Is it USB? SCSI? Perhaps your third-party NTFS driver, or your USB Storage driver, doesn't support drives that large. There were multiple revisions of NTFS and perhaps your NTFS driver only supports one as of NT4 or such.
Reply 2 of 7, by leileilol
You're asking for data loss imho. For accessing drives that big and NTFS, i'd use XP at a minimum
long live PCem
Reply 3 of 7, by cambalinho
thanks for all.. but i will wait for get more info.
why installing the 'ESDI_506.PDR' file, but i get an access denie? is the 'ESDI_506.PDR' file attributes or something?(i did it on MS-DOS and not on windows)
Reply 4 of 7, by Riikcakirds
As your computer boots press and hold the F8 key. At the menu select command prompt only. Then copy ESDI_506.PDR to WINDOWS\SYSTEM\IOSUBSYS
I have used the modified Winme version of ESDI_506.PDR (v1.0 dated 2006-07-21) by LittyX/Lixaanli.
It worked with a single partitioned 2TB drive I used as a simple test, filled the drive to 1.92TB and checked hashes.
BTW if you do the above mod and have a bios that is not 48-bit LBA you will get data corruption above 137 GB
As for external USB attached drives, Win98se/ME support 2TB without any patches.
Reply 5 of 7, by cambalinho
finally i did it with another patch.
but my external disk need more power.. i tested with another NTFS disk and works fine.. thanks for all
Reply 7 of 7, by Duffman
Use rloew's TBPLUS package if you want to do this sort of thing.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
