First post, by Cobra!
I wanted to try out WWF In Your House, so I found a cue/bin rom online, burnt it to a CD (making sure I selected the cue, not the bin), and installed it on my Windows 98 Laptop.
It installed without any issues, but when I played it, there was no music. I double checked to see if Windows 98 recognised the audio CD portion of the disc, and it does, and even plays in Windows Media Player. It just doesn't play in game.
I've tried multiple isos of the game, some even give checksum errors in ImgBurn, but even the ones that don't still don't play the music. I made sure I set the audio drivers accordingly on all of the installs I've attempted.
So what do I do? Are these just bad rips or do I need to configure something to get it working?
Reply 1 of 5, by elszgensa
Shiver me timbers.
Spoiler
Always remember, on these forums we gotta pretend like piracy doesn't exist.
.iso files don't/cannot contain redbook audio.
Does your original disc show the same issue?
Reply 2 of 5, by Cobra!
I don't have the original disc yet... I'll get back to you guys when I get a copy... Feel free to close or delete this thread. Sorry.
Reply 3 of 5, by feda
Cobra! wrote on 2023-08-29, 20:47:
I don't have the original disc yet... I'll get back to you guys when I get a copy... Feel free to close or delete this forum. Sorry.
That's okay, no need to delete the entire forum just yet.
Reply 4 of 5, by elszgensa
Alright, seems the mods have decided to leave this thread up anyways, so let's try to shoot some trouble.
First thing to check, open up the cue file you created from your disc. Does it mention the audio tracks, or just a data track?
If that checks out then skim this a discussion about a similar problem. I suspect it might be the elated to the "digital audio" setting that you should see when using WDM drivers, i.e. Windows/WMP is transferring the audio track "through the IDE cable" while the game, being a DOS title, has no concept of that expects the data to go through the separate audio cable. Though, seeing how you're on a laptop, I have no idea whether such a cable is even supposed to be installed. Look into what settings/alternate drivers may be available to you regarding this.
Have you found other DOS titles' CD audio to be working correctly, i.e. is this a problem specific to this game or all of them? If you have one available, you could also try a different title that actually checks the audio tracks as part of its copy protection or whatever, just to make sure DOS titles can see them in the first place. Off the top of my head I can only think of ROA: Shadows over Riva but I'm positive there are many others. WWFIYH simply doesn't care at all.
