First post, by claesbas
Hi, So I am working on a 166mhz mmx machine and I have a ASUS VX97 motherboard. Everything works great but there was no PS/2 mouse and all my attempts of getting a USB mouse working with a USB PCI board failed.
In the manual of the ASUS VX97 motherboard there is a page about an extra PS/2 bracket that one could purchase. Of course those are hard to get but I did find another one on pccables.com
606.9 KiB
However my guess here is that its connected differently than ASUS one:
62.4 KiB
209.54 KiB
In the manual there is this information:
675.52 KiB
Here is a closeup:
61.16 KiB
Could anyone that understands this guide me what needs to be done and what colors of the cables would be correct?
Reply 1 of 8, by weedeewee
One more photo of the back ( were the wires come in ) of the ps2 connector would've made it possible to verify the connections.
Do not ask Why !
Reply 2 of 8, by claesbas
Ah, here are on that end:
288.41 KiB
414.57 KiB
276.1 KiB
Reply 3 of 8, by mmx_91
If you have a multimeter you can identify which pin of the ps2 connector indeed corresponds to each wire. Then you can search for the pinout and match every signal to the wire itself and connect it directly on the mainboard.
To extract the pines is very easy by prying the plastic tab to release the pin so you can 'redistribute' them into the connector.
Reply 4 of 8, by claesbas
mmx_91 wrote on 2023-08-29, 20:09:
I do have a cheap multimeter but I am so lost when using that one - I only understand the continuity beep one, 🤣.
1 MiB
Reply 5 of 8, by weedeewee
the way I see it
brown is Mouse data
red is ground
green is mouse clk
yellow is +5v
The way the ps2 connector mainboard plug is populated should be fine.
Do not ask Why !
Reply 6 of 8, by claesbas
weedeewee wrote on 2023-08-29, 20:19:
the way I see it […]
the way I see it
brown is Mouse data
red is ground
green is mouse clk
yellow is +5v
oh, that was easy then. Thanks! I will test it then and see if it works.
Reply 7 of 8, by mmx_91
the way I see it
brown is Mouse data
red is ground
green is mouse clk
yellow is +5v
Yess I'd say the same from the connector view, but if you want to double check it, the beep funcionatily is the one you need haha, good luck!
