First post, by clb
Here is something mildly interesting. If on my Cyrix 486 80 MHz PC I set sound output device to PC Speaker in Pinball Fantasies, I start to get these 100% recurring artifacts on the ball, jagged/sawtooth parts of it are missing. No other visual glitches in the game that I could find. PC Speaker audio sounds good.
These artifacts only occur when the ball is vertically located on certain fixed y-coordinates/scanlines modulo some value on the table.
A slow down video is at https://youtu.be/wk88GgAc_9k
Any theories what might cause this? I was theorizing that the game board is predrawn in VGA memory, and it would only clear and draw the ball at each frame in vblank, but why would it weirdly miss only part of the ball, and only on specific scanlines?
The horizontally repeating patterns of the glitch have to do with Mode X, which organizes every four consecutive pixels on separate VGA memory planes, but I can't quite understand why it can happen that the middle of the ball would vanish.
Does your steel ball get eaten by Jaws if you're playing on PC Speaker?
Reply 1 of 13, by clb
Oh, forgot to add, this was tested on ATI Mach64, fairly fast card. Although, I don't think this would be graphics card dependent (except maybe due to framebuffer timing/speed reasons).
Reply 2 of 13, by kixs
I used to play Pinball Fantasies with PC speaker sound a lot back then and I never noticed it (I had ISA only 486DX2-80 with no sound card). Might be some configuration problem.
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Reply 3 of 13, by clb
Interesting to know. Yeah, might be some odd combo.
I now recall there is a sound quality setting in SETSOUND.EXE. Tried setting Low Quality, but that did not affect the glitch at all (the video above was recorded with PC Speaker setting at MAXIMUM). Also tried toggling PC Turbo button while game is running, that didn't seem to modulate the glitch either. So it is somehow behaving quite speed independent.
Reply 4 of 13, by bregolin
Pinball Fantasies is quite picky when it comes to video cards- are you able to test it using a different one?
Reply 5 of 13, by mkarcher
Pinball fantasies synchronizes the timer IRQ to the horizontal sync (maybe not at 31.5kHz, but at 15.7kHz). The complete drawing engine is locked to the frame rate. As you correctly suspect, this game doesn't render each frame completely, but it just draws the ball and the flippers as required. The ball is supposed to be redrawn during vertical blank, but it seems the game engine is not locked correctly to the vertical timing, suspecting the vertical blank when in fact the display is at the center. I wonder whether something goes wrong with counting the scan lines twice, so the end of frame is suspected at scanline 200 instead of 400. Redrawing the ball at scanline 200 (just after the displayed area) is the correct thing to do if Pinball Fantasies set to the "standard" video mode, but the wrong thing if Pinball is set to the "high-res" video mode.
If a different video card doesn't fix the issue, I suspect your copy of Pinball Fantasies might be broken. You don't need a fast video card for Pinball Fantasies: I played it with DAC-on-LPT sound on a 12MHz 286 computer with a mediocre ISA video card without any issue, so I am not surprised that processor or bus performance is not the root cause of the issue.
Reply 7 of 13, by Imperious
Looks like blood streaks on the ball. Maybe it considers running that wonderful sountrack and special effects through the PC Speaker as an evil act 😀
Really though I don't have a clue.
Reply 8 of 13, by the_engineeer
Regarding the DOS version of Pinball Fantasies, is there a way to trigger a GPF fault when running this game?
Strange thing to ask, but I remember that I encountered this in the early 90s and when it happened the game devs made it so a hilariously ugly drawing of a military man appeared with the caption "Generalens fel" (The generals' fault in swedish).
It would be fun to make a screenshot of this and preserve it for future generations =D
Reply 9 of 13, by Grzyb
the_engineeer wrote on 2025-01-17, 08:33:
You've mistaken it with Pinball Illusions...
The attachment pi.jpg is no longer available
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 10 of 13, by the_engineeer
I’m pretty sure that this is the case for both of these games, but that is absolutely the error I was talking about.
Reply 11 of 13, by Grzyb
the_engineeer wrote on 2025-01-17, 09:08:
Pinball Fantasies - at least the original version - runs in real mode = no memory protection = impossible to GPF.
But maybe some later release does use a DOS extender?
Reply 12 of 13, by the_engineeer
Ah.
You’re certainly right, I stand corrected.
I will try to replicate the error myself in Illusions, it seems that memory managers are disliked by this game so maybe I’ll try that way 😀
Reply 13 of 13, by MMaximus
bregolin wrote on 2023-08-30, 21:46:
yes FWIW I tried it once with a TGUI9440 and I remember getting weird colours in the menu and possibly in game, IIRC
Hard Disk Sounds
