First post, by aaronkatrini
Hi all,
I had previously received this lovely and quite rare AM2 Motherboard with AGP slot. Unfortunately it had many bulging caps and decided to recap it. The new caps have now finally arrived but I can't seem to find the piece of paper I wrote the values 🙁 I kindly ask if someone has this board at hand if they can see what the values are and report back, that would be greatly appreciated.
Going from memory and using photos I found online, I think there are only 4 types and I've so encircled in the photo by color (Red, Yellow, Violet, White) So only need to check one cap per color 😀
Thanks in advance!!
Reply 1 of 5, by Karbist
Red and White: 1000uf 6.3v
Violet: 3300uf 6.3v
Yellow: 1000uf 16v
Reply 2 of 5, by Horun
Nice Karbist ! OP: next time use your cell phone and take some picture before you de-solder 🤣
Reply 3 of 5, by CharlieFoxtrot
aaronkatrini wrote on 2023-08-31, 22:54:
Are you me? I mean, this is exactly something that most likely would also happen to me at some point.
Yesterday I completely lost my s**t in my workshop for very similar reason. I reccaped the secondary of an old 5V heavy Enermax PSU. I had taken the PSU apart about a week ago and while doing so, I put all the screws to a small zip bag. Yesterday, after the recap I started to put the PSU back together and I couldn’t find that zip bag anywhere, goddamit. Gladly I had replacement screws, only problem was the grounding lead that is attached to the PSU chassis with a bolt. I don’t know if it is with inch twist or what, but I couldn’t find a replacement bolt that would fit nicely so I had to mcgyver it a bit.
But damn that is infuriating and only one I can blame is myself 🤣
Reply 4 of 5, by aaronkatrini
@Karbist Thank you so much!!
@Horun Yes, indeed, need to do that, but writing everything on a piece of paper seemed more "professional" 😀
@CharlieFoxtrot we're on the same boat brother 😜
Reply 5 of 5, by Cobra_MK
Hello, can you tell me what capacitors do you used for that board?
Have 2 of them one is completely new but will not start so I will try to bring it back with a complete recap
