First post, by ikethefox
I have a Zeos Ambra model 486LTV that will POST but not boot further. It glitches out the Energy Star and Award logo after posting and then it becomes non responsive.
Reseated the CPU, and BIOS chip, RAM is correct FPM style for the chipset.
I have attached images of the system and the error.
Reply 1 of 12, by ikethefox
Booted it with an ISA POST card, get error FF63.
Which seems to deal with INT 19h
Reply 3 of 12, by ikethefox
Same with disk or without.
Reply 4 of 12, by Zerthimon
Code FF means POST is finished, looking for boot block. Insert an external ISA card (disable the on-board one, if possible), as the on-board one is, clearly, having problems.
Reply 5 of 12, by ikethefox
I don't have an external ISA controller on hand besides the one in my other 486.
Reply 6 of 12, by ikethefox
Tried with my ISA card and still doesn't work. Onboard one has no option to be disabled.
Reply 7 of 12, by ikethefox
Acer m5105 model disk controller chip.
Reply 8 of 12, by rasz_pl
it it was glitched from the start then I would also point at integrated graphic card, but only after completing initialization is weird, almost makes me say corrupted bios? but it does sent POST code indicating it finished correctly so I dont know
this is the board https://theretroweb.com/motherboards/s/dtk-pk … 0062s-ver.-1.00 sadly no bios dumps
JP23 disables build in VGA, test again with ISA graphic card, also go over all the jumpers with https://theretroweb.com/motherboard/manual/33088.pdf
Reply 9 of 12, by harris286
mb bios corrupt
Reply 10 of 12, by ikethefox
I'm probably gonna give it away to Free Geek Twin Cities since I don't have an EEPROM programmer. Did use the CPU and RAM for my other 486.
Reply 11 of 12, by Windows9566
could a crossflash work, i know the onboard video will not work, but try to rule out a bad BIOS by using a different EEPROM with a different SiS 461 BIOS
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 12 of 12, by Zerthimon
Another idea ? Cache... try w/o cache ?
