First post, by GloriousCow
I'm happy to announce a new CPU Test Suite for the Intel 8088 CPU has been merged into Tom Harte's excellent ProcessorTests repository at https://github.com/TomHarte/ProcessorTests/tree/main/8088.
If you're unfamiliar with JSON CPU tests, I've written a short blog article with more information, which you may read here: https://martypc.blogspot.com/2023/09/a-test-s … intel-8088.html
This test suite is extensive - covering over 300 opcode forms, consisting of over 3 million individual tests spanning nearly 90 million cycles.
EDIT: We've reorganized things a bit, the 8088 test suite is now hosted at https://github.com/singleStepTests/8088
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 1 of 1, by GloriousCow
Version 1.1 was recently merged, no actual test changes but the test disassembly was updated.
I've been playing around with data mining the tests with Python. Here's an example of the sort of thing you can do, histograms of cycle execution time for all 8088 instructions:
warning: big image
324.8 KiB
8088 cycle timings
