Slot A thunderbird mod?
First post, by supercordo
Hello, Awhile back i seen where someone added resisters to a Pentium pro CPU to make it more stable at higher overclocks. I'm wondering if its possible to do the same with Slot A thunderbirds. In the picture you can see that it is blank. The thunderbird cpu for socket A has them filled. Does anyone wanna test this theory out?
Reply 1 of 7, by supercordo
Just bought 10 of these https://www.ebay.com/itm/325276918502 Figured why not. Could also be some higher rated cores hiding. I have a couple Durons I can sacrifice for the cause.
Reply 2 of 7, by shevalier
supercordo wrote on 2023-09-16, 03:23:
Your core is cracked, capacitors will not help it 🙁
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 3 of 7, by Sphere478
some of those may be resistors but most are probably decoupling capacitors.
taking some from a same core socket 462 is probably an option that would get you close to correct values. you would have to measure those pads and figure out which pads connected to vss and vcc those would be the ones that you would populate.
if it helps overclocking, it won't likely be by much.
Sphere's PCB projects.
Reply 4 of 7, by shevalier
Sphere478 wrote on 2023-09-21, 05:16:
All of these are Reverse Geometry Capacitor (RGC) has its terminations on the longer side of its rectangular shape.
https://www.kyocera-avx.com/products/ceramic- … hip-capacitors/
100 and 10nF * 6.3V
At one time it was fashionable to use them on processors.
It’s better to replace each one with a stack of 0603 capacitors, like 1uF+0.1uF+10nF.
Reply 5 of 7, by Sphere478
shevalier wrote on 2023-09-21, 06:25:
All of these are Reverse Geometry Capacitor (RGC) has its terminations on the longer side of its rectangular shape. https://www. […]
100 and 10nF * 6.3V
They do look pretty sexy on the pentium mmx 😀
Reply 6 of 7, by supercordo
shevalier wrote on 2023-09-21, 04:01:
That was just a photo off google.
Reply 7 of 7, by The Serpent Rider
Rookie cracks. Here's how you do it: Crimes Against Silicon: Scuffed CPU/GPU cores
But yeah, main bottlenecks for overclocking would be silicon lottery and motherboard VRM.
