M919 DMA on Windows 98SE
First post, by tauro
Hello friends,
I was doing some tests with this board and I couldn't get Windows 98 SE to boot once I enable DMA. I'm using the on-board IDE controller, Intel DX4, 33MHz BUS.
Der Sammler reported that setting the L1 to WT would fix it (jumper JP8A) but it doesn't help for me.
I tried all the BIOS I could get my hands on:
Latest M919 (1998), M919 05/06/1996, SYL8884, M921, 2A4X5000...
Does anybody know if there's a way to get it working? I tried three boards so far and none of them works with DMA. Win98SE is unbearingly slow and it's a bummer.
Reply 1 of 2, by jakethompson1
The UM8886BF has the bit set in its PCI configuration space as if it supports bus mastering, but it doesn't support the Intel Triton-compatible PCI Bus Master IDE Controller specification described here: https://pdos.csail.mit.edu/6.828/2018/reading … E-BusMaster.pdf which is what the DMA checkbox in Win95 expects. The Linux 2.2/2.4 IDE code has an exception written into it to block DMA on the UM8886BF for this reason (in there among all the other buggy PCI IDE implementations). At least unlike the more notorious PCI IDE chipsets it won't lose data.
At least one revision of the UM8886BF, that found on my GA-586AM, does support bus mastering. But it does not support scatter-gather I/O. That's needed because in a paging-based OS, every time your buffer crosses a page boundary, the physical memory address is discontinuous. The Triton takes a big table in memory with memory addresses and number of DWORDs to transfer. Instead, the CPU has to babysit the UM8886BF, loading it with a memory address and dword count, then spin until it finishes, then load it with the next page's physical address, and so on. It was still faster than PIO in my testing, but it under-performs compared to a proper Triton.
It's been some time that I looked at it but it doesn't actually do DMA transfers between the chip and drive. Instead it does bus-mastered PIO as if that were a thing. It might do the opposite too; it's been some time since I have looked at it.
The UM8886AF and BF do have "FIFO mode" which speeds up PIO reads, but the FIFO has to be manually toggled between disabled, filling, and draining during each read. Multi-sector transfers also help. You might try the driver from UMC that supports these features, but it's said to be buggy beyond Win95a. I've done a bit more research in this area but am not prepared to release anything yet, partly because of the risk of data loss; DM me to discuss more.
Reply 2 of 2, by tauro
jakethompson1 wrote on 2023-09-18, 19:17:
The UM8886BF has the bit set in its PCI configuration space as if it supports bus mastering, but it doesn't support the Intel Tr […]
Wow! That's what I call a detailed reply.
Thanks for taking the time to share all this information. I couldn't find it anywhere else!
I'll DM you.
