First post, by buckeye
The lure of nostalgia has led me down this rabbit hole as I finally found (maybe!) a way to play an arcade game I obsessed over back in the late eighties.
That would be John Elway's Team Quarterback by Leyland. There's no telling how many quarters/hours I sacrificed to play this game but had me hooked
on day 1. Because of this game I got into PC gaming in 1992 later on when Konami's NFL hit the shelves. Back then I would come in early to work and play
it on my co-worker's ALR 486 which he kindly permitted. A whole host of PC football titles followed after that but none quite captured the magic like
that arcade game back in the day.
Now to my current predicament. Mame is uncharted territory for me and from what found out so far there you have options when it comes to getting started.
I installed Mame itself without a front end and played a game without a hitch no problem. Would a front end be preferable like Launchbox or retroArch and
would it make it easier to calibrate a joystick? On a side note what joystick would be recommended for these arcade style games?
    5.17 KiB
    16.33 KiB
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 1 of 12, by shamino
I'm at least 10, maybe 15 years out of date on MAME, and I won't even try to talk about frontends.
I don't know anything about this game, but look for a controller that's a good match to the arcade hardware you care most about replicating. Are you saying you need analog? Most arcade games use digital joysticks. If digital, did this game uses microswitch joysticks/buttons or were they leaf switches?
You can open a lot of options by using an adapter that lets you use joysticks intended for game consoles.
Ever since the 1v1 fighting game craze, there have been premium joysticks made for consoles that use arcade quality microswitch parts. Not the mainstream ones from Sega/Nintendo/etc - the arcade quality joysticks were made by small obscure companies and were expensive, so their population is low. As such it's hard to predict what you might find 2nd hand at a low cost. If you don't mind the high price for buying new, there's probably still arcade sticks being made for PS5 or whatever, and maybe even for PC.
For example, I have an "Arcadian" microswitch stick intended for the Sega Genesis which I sometimes connect to PC using an adapter. There were similar joysticks made for SNES and newer systems, continuing to the present day, but joysticks of that quality have always been a niche item.
I think the premium joysticks almost always use microswitches because that's what 1v1 fighting fans like. However, I think most arcade games of other genres used leaf switches. Those might be hard to find as a ready-made product. If you want leaf switches you might have to modify an existing joystick or build your own. Or if you're buying new, maybe leaf switches are available as an option.
In the controller I mentioned above, I've thought about trying to convert/replace my joystick with leaf switches, but I've never looked deeply into the feasibility of that.
Reply 2 of 12, by spiroyster
I think most non-analog arcade sticks were microswitched due to robustness (these things were abused almost daily) and ease of replacement (in many cases operators were responsible for maintence and repair... especially due to ware and tare). Also note the buttons used the same microswitchs as the sticks so no need to keep different parts.
Not familiar with John Elway's Team Quarterback, but most US arcade cabinets in late 80's used Happ (now known as Suzo Happ) controls (sticks and buttons) as opposed to Japanese Seimitsu/Sanwa and since LeLand is US based I would say Suzo Happ controls would give the most authemtic feel. Controls certainly look Happ.
For tactile autheticity, aside from getting a cabinet, you can pick up a (pandora) panel (or make your own from MDF or something) and use actual arcade buttons and sticks wired up with a 'Zero-Delay' pcb. Lots of reproduction layouts these days, Zero-delay can be had for next to nothing from China (avoid Chinese sticks and buttons though... they are shite), and the arcade buttons/sticks can easily be had for cheap locally in the US.
Failing that, as mentioned, an arcade stick for consoles can be used, but you need to either get a converter (converters can be expensive depending on the console) or rewire with a Zero Delay (which is USB). HORI is always a good bet and the HORI sticks from PSOne (or earlier) era are great. Might have trouble replacing the stick (depth issues), but they tend to be good anyway and most buttons are standard 30mm dia (although HAPP buttons are deep so won't fit most...if any). Done this with many sticks (SEGA/NeoGeo/HORI I like Seimitsu sticks and Sanwa buttons), very easy to do, don't even need soldering in many cases. Newer consoles use USB anyway, however there are a lot of cheap sticks (feeling and quality) and the quality ones tend to be very expensive (later Hori stuff for example).
John Elway's Team Quarterback seems to have an interesting control configuration (8-way and Analog?) so maybe a custom control panel using two Zero-delays may be the best option? If this is the case then you might be able to connect both these sticks via a single Zero-Delay (can take 16 buttons and 8 directions... so usual analog and then 8 of the 16 buttons for the 8 way stick?) or each player would require 2 input devices, unsure how many Windows/MAME will take at any one time (never tried more than 2 😉).
Reply 3 of 12, by buckeye
Appreciate the comments and ideas. Went to a local Micro Center and they had an arcade joystick assembly but it's seemed to be suited for a
standalone cabinet not simply plugging into a pc.
Came across this site: https://shop.xgaming.com/
X-arcade's products might work except they're so darn huge and expensive, as the saying goes "you have pay to play".
Reply 4 of 12, by sneeker
Been playing around with Mame for 20ish years, never built a cab or anything but used quite a few front ends with it as well.
Ive just always used a Hori Ps3 stick that Ive had years, have a couple of other sticks like the namco ps1 stick and an official ps1 stick as well, the namco is easily the best one. Most of the time I used mameui but thats been officially put to pasture, theres now IV Play that is sort of the replacement for it.
Reply 5 of 12, by Repo Man11
I began playing arcade games in the late seventies, and spent every spare quarter I could scrounge at the local arcade. Asteroids, Galaga, Defender, Missile Command, Pac Man, Ms. Pac Man - but I never really mastered any of those. My obsession began when I discovered Gravitar in late 1982. That became my game, and I became one of those guys who would play for an hour (or longer) on one quarter. But by 1984 I grew tired of it, and the fad had passed. I didn't play any computer games again until 2001, when I had a computer that could play Jane's WW-2 fighters.
Reply 6 of 12, by twiz11
Repo Man11 wrote on 2023-10-04, 18:54:
Emulation isn't the same as Realisation (Real or Native hardware). You want that smell of burnt plastic from the caps and batteries and screen burn-in to make it authentic
iami
RETIRED
This user is no longer active on VOGONS.
Reply 7 of 12, by Robbbert
sneeker wrote on 2023-10-04, 16:06:
Most of the time I used mameui but thats been officially put to pasture...
Unofficially, it continues. You can get the latest one at https://messui.1emulation.com
Reply 8 of 12, by Milew
Never play "John Elway's Team Quarterback" but research a little. Many games is not easy to play on MAME well because they have a special controls. This game have a Joystick, and something name "stick" ? Pictures about cabinet is bad, but this "stick" look like small stick 😉 Black and white stick and it is analogue.
For this game you don`t need only classic digital joystick but some analogue too who will be acting like original "stick".
Think that any joystick with classic "mushroom" analogue will be O.K.
Reply 9 of 12, by twiz11
Milew wrote on 2023-11-10, 22:31:
i love the euphemisms.
iami
RETIRED
Reply 10 of 12, by hard_fault
I stand by my purchase of this Mayflash Universal Arcade Stick F500 Elite. Currently in the market for a second unit. This thing is fantastic. I feel like Hank Hill and his old pickup truck: "I can't push her by myself, she's too solidly manufactured.."
Reply 11 of 12, by twiz11
mame, now acade emulators are nice wouldnt you like the real one working from 1992?
iami
RETIRED
