First post, by kapybara
I can't get Command & Conquer: Renegade to run on my retro PC no matter what. Nearly 100 games I threw at this system all worked (eventually), except this one and I can't find any relevant info either on Vogons, PCGW or anywhere else.
Here are my PC specs: PIII 1GHz (Coppermine 133MHz FSB), 256MB RAM, Voodoo 3 3000 / GeForce 4 Ti 4200 (tried both), PC Chips M768MR MoBo with latest BIOS, Monster Sound MX300 (stock Vortex 2 drivers v2041)
And here's what I tried:
unpatched game (v1.0 EUR retail), patch v1.037, no-cd patch, reinstalled Windows, DirectX 8.1, DirectX 9.0c, using Voodoo 3 (driver V1.07.00), using Geforce 4 (drivers v41.09), taking out the sound card.
The result was the same in all cases - "invalid page fault in module GAME.EXE" after launching the game, not even the intro movie starts playing. The installer (which also plays movies and renders 3D stuff) worked fine. 🤔
To add insult to injury, the installed game worked on my regular Windows 10 PC, lol.
Has anyone experienced this? Any luck with getting it to run?
    _except.txt
    56.34 KiB
    31 downloads
    54.9 KiB
Reply 5 of 9, by kapybara
I tried installing NUSB and Daemon Tools in a PCEm VM, where the game ran and either didn't affect it. Vortex and GeForce drivers refused to install without the hardware, so I couldn't test those. However, one possible culprit could be that the VM has Win98 with the default US codepage installed and there's a central european codepage on my retro PC. Sadly, this setting can't be changed without reinstalling the entire system.
Reply 7 of 9, by kapybara
After trying many different combinations of things, I finally figured out what the issue was.
When installing Win98, I didn't tick the box with "Communications" components. Renegade crashes without them. 🤦‍♂️
The components can be easily installed via Add/Remove Programs in the Control Panel.
    12.02 KiB
