First post, by wbahnassi
- Oldbie
Hi guys,
I'm building a 386SX 16MHz machine+case. It's a very simple and basic one: Mobo+VGA+RAM+PicoPSU+floppy drive. No other cards and not even an HDD. Putting it all in a small-factor hand-made case to be used for speed-sensitive games, as it can de-turbo to 8MHz, so many XT-class games are now within reach.
The key point here is that it doesn't have a regular PSU (which typically has a fan that circulates air in the box). I've run the machine for a few hours. The 386 CPU gets hot, but not skin burning hot. In fact I could just keep my finger on it and cool it down that way. So I'm wondering if under this setup, a heatsink or fan of some sort is needed for the entire machine? I also checked the Pico PSU and it's barely even warm. So I'm only concerned about the CPU really. Thoughts?
Cheers!
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
